06-05-2014, 09:43 AM | #1 |
18
Rep 268
Dyno Expectations
Hey guys,
I have an 09 135i coupe 6AT with following mods: COBB stage 2+ tune AR catless downpipes Berk street axleback DCI air intake cones ETS 5 Intercooler Alpina B3 transmission tune stock chargepipe Heading to get a car dyno tomorrow, what should my horsepower expectations be? This way I will know if there is a boost leak somewhere. Thanks!
Custom Wedge MHD 2+ Aggressive, AR Catless DP, ETS 5 FMIC, BMS DCI, BMS OCC, Berk Axleback, CF Diffuser, CP-E Chargepipe
06-05-2014, 10:33 AM | #2 |
116
Rep 1,158
I'm not sure but I would assume above 350rwhp.
Do you assume you have a boost leak? I'm sure when you look at the dyno chart afterwards you can tell if it's leaking boost or you could do a couple of logs and let some people on the forum check your stuff. |
06-05-2014, 10:36 AM | #3 |
88
Rep 824
It depends on the dyno they all read different. U should be over 350 at wheels. I put down 350 with cobb stage 1 aggressive and dci with oem down pipes
06-05-2014, 10:40 AM | #4 |
172
Rep 2,347
380whp give or take
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms |
06-05-2014, 12:10 PM | #7 | |
Joint Chiefs of Staff
24282
Rep 190,975
As for dyno, you probably want to run the cobb map and then compare it to stock. Since every dyno reads different just looking at cobb stage 2 numbers will not ,mean much. Also keep in mind its hot out there so your numbers might be lower that expected.
06-05-2014, 12:14 PM | #8 |
64
Rep 256
+1 on the charge pipe. It was the bane of my existence before I went with an aftermarket pipe with the Tial BOV. Most likely you'll leak boost from the DV's. Throw a couple gals of e85 in and get the COBB e85 map for the dyno.
06-05-2014, 12:52 PM | #9 |
18
Rep 268
Thanks everyone. Reason I suspect a leak is due to poor 1/4 mile time at the track a couple weeks back. 13.46 @ 107mph was my best. Granted i had awful 60' time of 2.2 seconds
Tires: Bridgestone Potenza 760 50% tread.
06-05-2014, 12:53 PM | #10 |
18
Rep 268
Suggestions on Charge Pipe? Is this a fairly easy DIY? The intercooler was a pain but still got it done with a friend's help.
06-05-2014, 12:54 PM | #11 | |
Rep 164
06-05-2014, 12:54 PM | #12 |
18
Rep 268
Pump 93 octane fuel and Stage 2+ COBB (aggressive) tune
06-05-2014, 01:17 PM | #13 |
18
Rep 268
06-05-2014, 02:21 PM | #14 | |
88
Rep 824
06-07-2014, 09:19 AM | #15 |
18
Rep 268
Came back 341hp. They couldn't do RPM wiring so no torque numbers.
06-07-2014, 10:19 AM | #16 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
^^^^ typically you need to bring a hex key to lift the engine cover.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
06-07-2014, 10:39 AM | #17 |
18
Rep 268
Yeah that's what they said they would have to do. I also couldn't stay in 4th gear for the life of me, the dyno chart is full of oscillations.
06-07-2014, 01:14 PM | #18 |
3129
Rep 5,264
^^^^ I posted how to make a stop that will keep you out of kick down, might be on this site. If a search does not show it let me know & I will cross post it.
Kevin
06-16-2014, 11:57 AM | #19 |
46
Rep 370
i think he has a pretty nice setup:
COBB stage 2+ tune AR catless downpipes Berk street axleback DCI air intake cones ETS 5 Intercooler Alpina B3 transmission tune stock chargepipe and what can he swap to get like 400whp? or dose he have to swap the turbo? |
06-17-2014, 12:11 PM | #21 |
18
Rep 268
Is it worth it going to a shop to test for boost leak? The one I called last week said I would FOR SURE know if I had a leak somewhere (doesnt seem obvious to me as car still feels powerful)
06-17-2014, 06:04 PM | #22 |
247
Rep 1,827
I'm fairly certain you have a boost leak. You should be running a lot faster with those mods. This is what I ran with just Cobb Stage 2+ aggressive, Helix FMIC and Raceland downpipes on 93 octane several years ago: http://www.1addicts.com/forums/showp...86&postcount=1
