05-29-2014, 07:14 AM | #1 |
13
Rep 138
Brakes & brake fluid - track use
Any downside to rotors if I switch to track pads for HPDE and then switch back to OEM for street use?
What brake fluid would people recommend? (8-10 track days planned along w DD duty during summer and fall). Thanks.
____________________________
?98 993 ?11 E82 1M ?13 E70 X5 |
05-29-2014, 07:37 AM | #2 |
677
Rep 547
I would have separate track rotors and DD rotors. Different pad materials building up on rotors will affect brake performance.
I ran track pads on stock rotors, ended up with some gouging of the rotor face. Machined them smooth for the stock pads swap and whilst okay initially, developed a shuddering under light braking. My advice, better rotors and pads for track duty, stock rotors and pads for DD. I use Motul RBF600 Search other threads for issues with the stock rotors on track. But then some people have no issues either |
05-29-2014, 07:40 AM | #3 |
4338
Rep 6,196
I bet the compounds will be incompatible. You will probably get a vibration which will lead to warped rotors. Generally, if you stick within one brand, you are OK. Hawk says all their compounds are compatible with each other, so use HPS or HP+ on the street, then a real track compound like DTC60's on the track.
05-29-2014, 07:41 AM | #4 |
37
Rep 381
No downside, it's what many of us do. Use a pad like PFC-08 that is not hard on the rotors. PFC's also bed in quickly which is a consideration when swapping back and forth. I haven't had any buildup problems with the 08's. I use Motul RBF 600 fluid since I bleed often and flush yearly. Ti brake pad insulators work well too to reduce fluid temp buildup especially when we're new to the track and tend to use the brakes too much.
05-29-2014, 01:37 PM | #5 |
24
Rep 391
2nd TXmtrhed set up. I have the same and havent had any issues. CarboTech XP10pads are also very easy on rotors and I found that they have almost as good of initial bite as the PFC's but they don't hold up to the heat as well and will fade a little toward the end of a long session.
Current - 2015 Cayman GTS White Borla Exhaust
Prev - AW 1M #43 USA Meisterschaft, N55 mids, AFE CAI, ER Charge, Wagner IC |
05-29-2014, 02:58 PM | #6 | |
157
Rep 1,409
With my Ti shields, I think I am overwhelming my XP10 pads more quickly now, because I also moved from 225/40R18 front tires to 255/35R18 EHP tires. The front brake pads have more work to do now, and build up more heat due to enhanced adhesion. Im not getting a soft pedal (boiling fluid), but I do need to step on the brake pedal harder (brake pad fade), and brake earlier. For my next set of front pads, I will move up from XP10 (1475* max temp) to XP12 pads (1850*F max temp). May also experiment with the first set of PFC-08 pads produced for the 135i, if I get them from Anish @ Speed-Freaks.net, in the June timeframe.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
05-29-2014, 04:32 PM | #7 | |
292
Rep 2,898
Neil |
05-30-2014, 11:15 AM | #9 | |
7906
Rep 11,785
Having separate track and street pads and rotors is expensive and very time consuming depending on model. The key when using different pads is to stay within manufacturer. Don't use. PFC street pads and HAWK track pads. They may be compatible or they may not. If I was a runner I wouldn't wear nikes for jogging and then new balance for running. I would stay with the same company for fitment. As far as fluid. I run castrol SRF. It's amazing and far equals most other fluids in dry boiling point and far exceeds most other fluids with respect to dry boiling point. Things like " bleeding often" from the caliper are simply not needed. Brake pedal feel doesn't change expect for pad level. You Spend more up front for but get a better fluid and less maintenance. Flush yearly. |
05-30-2014, 11:22 AM | #10 | ||
7906
Rep 11,785
06-02-2014, 10:43 AM | #12 | |
157
Rep 1,409
The Ti shields are really a temporary solution, to save your OE calipers (pistons, boots, and paint yellowing) if you are not planning a front BBK upgrade in the near future.
06-02-2014, 12:38 PM | #13 | |
292
Rep 2,898
I'd also run them in the rear, but none are (yet) made for that caliper. And, yes -- first upgrade your brake fluid (I run Motul RBF600) and pads (I prefer PFC-08 for HPDEs). Neil |
06-02-2014, 02:36 PM | #14 |
37
Rep 381
When I ordered mine from Hard Brakes I received 4 shields, two inner and two outer for the front caliper. Since I was only worried about the heat transfer to the single piston I modified the outer ones to fit the rear inner pads. Win!
06-02-2014, 02:40 PM | #15 |
157
Rep 1,409
The 135i has 6 pistons in each front calipers, so need 4 TI shields in the front as compared to your 1M.
06-02-2014, 08:02 PM | #16 |
Rep 12
Just to share my experience. I tracked the car for 1.5 track days completely stock before rotors severely warped. BMW replaced rotors but added Ferodo DS2500 pads. They worked well for 3-4 track days but I didn't like the feel of these pads. I then went to PF front rotors and PF08 pads all round ... I ran a bed in process prior to tracking the car but within 4 laps on track I had severe shudder in front brakes and stopped driving it very dissapointed. I am now on stock rotors with Pagid RS19s all round. So far two track days under my belt with this setup up and all going well. When first installed these pads were very noisy for street use but after two track days they are much quieter. I don't change from street to track pads because of the hassle factor.
06-02-2014, 08:44 PM | #17 | |
157
Rep 1,409
How is the modulation, bite, and consistency of the Pagid RS19's? Last edited by dcaron9999; 06-03-2014 at 01:49 PM.. |
06-02-2014, 09:37 PM | #19 | |
292
Rep 2,898
How did you cut them. Dremel? Neil |
06-03-2014, 01:27 AM | #20 | |
18
Rep 442
Are you sure RS19 don't squeal like a truck? If so, either this vehicle is not being driven on public roads (as for myself), or you must be braking hard on public roads |
06-03-2014, 01:34 AM | #21 |
Rep 12
Before the track days the Pagids were squealing BAD ... turning heads for all the wrong reasons. But no worse than the PF08s. Ferodos DS 2500 were fine on the noise front. After two recent track days with the Pagid RS19s the squeal is now very minimal (others may have a technical reason for this phenomenon), but enjoying the relative silence. I run Proxy 888s and installed front camber plates.
06-03-2014, 06:45 AM | #22 | |
7906
Rep 11,785
Going to an autocross is a great way to get rid of the squeal for a short period of time. Or go back to the track..... Braking hard in a short distance on the street also helps reduce squeal or chatter from the pads for that single brake application. Of course it can be hazardous to your rear bumper if there is traffic behind you. |
