05-27-2014, 09:18 PM | #1 |
Joint Chiefs of Staff
24201
Rep 190,807
BMS Wheel Spacers *** Lowest Price Guarantee *** Extreme Power House ***
Wider Stance = Better Handling & More Aggressive Looks Easily widen the wheelbase of your BMW with a set of BMS wheel spacers for superior handling and roll reduction while dramatically enhancing the look of your BMW. Wheel spacers push your rims and tires out flush with your wheel well for an instant "fat" aggressive look, better lateral stability and better handling. Also great for creating clearance for aftermarket suspension or big brakes or just making the car look awesome. These super strong BMS spacers are custom designed for your BMW ensuring a perfect fit. There are no markings on the outside edge for a stealth appearance. Each pair of BMS wheel spacers come with aircraft grade 10.9 heat treated extended black wheel bolts. Individualize your BMW today with BMS wheel spacers. Burger Motorsports BMW Wheel Spacers are sold in pairs (2pcs). They are hub-centric and come with the required 10 black longer wheel bolts. No need to search for expensive bolts to match, the're included. Most wheel spacers on the market do not come with the necessary bolts and don't have a lifetime guarantee. Quality, function and piece of mind can be found in every wheel spacer BMS makes. What do the experts recommend for your BMW? Most BMW vehicles can have up to 18mm in the rear and 10mm - 12mm in the front. BMS Recommends 12-15mm rear and 10mm - 12mm front on OEM BMW rims and tires. 15MM, 18MM and 20mm spacers might require slight fender rolling on the rear of some vehicles. Some go 18MM all the way around. It just depends on how wide you want to go. BMW Wheel Spacers by BMS Provide Better Handling by widening the Wheelbase Provide A Wider More Aggressive Look and Stance Specifically Designed for your BMW Guaranteed for the Life of your Vehicle 10 Aircraft Grade 10.9 Extended Wheel Bolts Included Light Weight Anodized Black Aluminum Special Pry Tabs on the Back for Easy Removal 1-Piece Spacer with Hubcentric Factory Lip Strong Solid Design & Appearance Available in 10mm, 12mm, 15mm, 18mm, 20mm
06-03-2014, 01:47 PM | #2 |
24201
Rep 190,807
Bump!
06-13-2014, 01:51 PM | #4 |
24201
Rep 190,807
Bump!
06-26-2014, 02:29 PM | #6 |
24201
Rep 190,807
Bump!
07-07-2014, 02:31 PM | #7 |
24201
Rep 190,807
Bump!
08-01-2014, 03:20 PM | #10 |
24201
Rep 190,807
Bump!
08-10-2014, 02:23 PM | #11 |
24201
Rep 190,807
Bump!
08-16-2014, 03:57 PM | #12 |
24201
Rep 190,807
Bump!
08-23-2014, 01:56 PM | #13 |
24201
Rep 190,807
Bump!
08-31-2014, 03:01 PM | #14 |
24201
Rep 190,807
Bump!
09-16-2014, 01:36 PM | #16 |
24201
Rep 190,807
Bump!
09-24-2014, 02:19 PM | #17 |
24201
Rep 190,807
Bump!
10-06-2014, 02:20 PM | #18 |
24201
Rep 190,807
Bump!
10-16-2014, 02:03 PM | #19 |
24201
Rep 190,807
Bump!
10-27-2014, 08:52 PM | #20 |
24201
Rep 190,807
Bump!
11-05-2014, 06:53 PM | #21 |
24201
Rep 190,807
Bump!
11-13-2014, 12:16 PM | #22 |
24201
Rep 190,807
Bump!
