05-27-2014, 01:29 PM | #1 |
225
Rep 3,094
M button MPG observations
Cruising at ~80mph I was noticing 39-40 MPG with the M button off.
Without changing any inputs and pressing the M button showed an instant drop in MPG of ~15MPG. This is using the display in the cluster after having instantaneous MPG activated in my car. |
05-27-2014, 01:35 PM | #2 |
119
Rep 898
Drives: '69 GT3, GT4, 1M, 912
I would expect that if you don't back off the accelerator pedal at the same time. The M button re-maps the throttle, so if you were driving at constant speed before you'll be accelerating after you press it. However if you drive at the same constant speed over the same stretch of road, say maybe with the cruse control on, I'd expect no difference in consumption.
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
05-27-2014, 02:24 PM | #3 | |
Rep 60
05-27-2014, 02:59 PM | #4 |
192
Rep 893
Drives: 135is :) 192/586
Not a 1M or any M-car driver here but...I'd expect that the fuel consumption would drop assuming an identical amount of throttle input. Try it on a flat road + cruise control (constant speed and most likely constant RPM). You should see similar MPGs with this test.
I do not know how the M button works 100%. but with your results, it's safe to say that it remaps the throttle sensitivity by a good amount. For example, 1/4 deep with M button activated = 1/3+ deep without button. |
05-27-2014, 05:22 PM | #5 |
Moderator
29418
Rep 13,107
Here's what BMW specified about it (see section 4.1.2. at pages 14-15):
BMW_1M_Technical_Training.pdf
///M is art ↔ Artemis
05-28-2014, 11:56 PM | #7 | |
13
Rep 138
I've never done better than 25-28 mpg.
____________________________
?98 993 ?11 E82 1M ?13 E70 X5 |
05-29-2014, 10:32 AM | #10 |
116
Rep 3,070
+1...similar to what I've seen. Less than 10l/100 km. you got to be going 90 km/h at sixth on cruise control for some time.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
05-29-2014, 10:55 AM | #11 |
Rep 47
OP is probably quoting instantaneous (or close to instantaneous) consumption figures in 6th gear around 90-100 km/h. Only then would he be able to see such an increase in consumption figures so quickly after pressing the M button, thus moving the virtual pedal position "further forward". It's perfectly normal!
05-29-2014, 11:08 AM | #12 |
Moderator
29418
Rep 13,107
6l/100km = current fuel consumption on a downhill slope. Hard to believe that that could be an average fuel consumption for a 1M.
05-29-2014, 01:06 PM | #13 |
7
Rep 99
im getting an average of 19L/100km city drive with m button off. no more than 250km per tank. i bought my car second hand and i thought its normal before i spoke to other 1m owners who are getting 400km per tank in a similar driving condition so i took it to the dealership today and they will connect it to the computer and see if the gas ratio is correct. btw my driving style is not aggressive
05-29-2014, 01:30 PM | #14 | |
116
Rep 3,070
05-29-2014, 01:52 PM | #15 | |
Moderator
29418
Rep 13,107
For example: below are statistics of my recent journey to the Italian Dolomites (Alps mountain range) and back. This included 'spirited driving' on the Autobahn on long stretches where no speed limit applies, slow driving in road work queues and cities, gas-guzzling power driving on steep hill climbs, etc.
05-31-2014, 01:30 PM | #16 | |
155
Rep 283
06-01-2014, 11:22 AM | #18 | |
Newbie
Rep 68
As for the drifting off topic - Im quite new to manual, so I often forget to change gears in 100-150m stretches between speed bumps, etc., so Im at times on high RPMs. Add my A/C being on 70-100% all day due to the now 45(C) degree weather in Dubai and my AWRON gauge's bad positioning. Plus I drive pretty aggressively. All in all around 20L/100km 15l/100kms sounds pretty good right now
AW 1 ///M
Exterior: Manhart CF Hood, Trunk, Rear Diffuser, Angel Eyes, CF Side Mirrors Interior: Manhart CF Full Upgrade, Awron Gauge, UUC EVO3 SSK, BMWP Flat-bottom Alcantara Wheel. Performance: Manhart Stage 4 Tune (+ CF Airbox, FMIC, Oil Cooler), Akra Titanium Full Exhaust + cat delete, Manhart Headers, cp-e CP, HKS BOV, Quaife Helical Diff, CDV Delete. |
06-05-2014, 12:50 PM | #19 |
7
Rep 99
ok gents, just came back from the dealership and apparently the gas ratio is pretty much fixed and every 1m has the same setting.
so the guys used the i drive to go into vehicle setting and from there you can see your average speed and gas consumption. i never played with this before and was quite surprised at my average speed which only came to 20.9 km per hr, so this explains why my milage per tank was so little. |
06-05-2014, 10:10 PM | #21 |
7
Rep 99
quite hard to forget while you are at the gas station twice a week handing out 60 bucks for yr car to be stuck at traffic jams hahaa, btw i saw yr thread about intake, i have afe dual open intake n i disagree with others quoting that it makes little to no differences to the performance as i really feel the rpm goes up a lot quicker with in installed n it makes a pretty cool sound too
06-07-2014, 12:59 AM | #22 | ||
225
Rep 3,094
I played with it a little bit today and I had similar results. Yes if I am down on the throttle more then the car surges forward when the M button is activated but in the observation of my original post the car did not accelerate. |
