05-26-2014, 04:34 PM | #1 |
121
Rep 1,555
Carbon fiber driveshafts
seeing the benefits on the new M3/M4 of these driveshafts, anyone thought of
having one made for 1M? These guys seem to do custom jobs http://www.bactechnologies.com/high-...50-driveshafts Thanks for feedback!
2011 E82 1M VO
2013 F84 35i VO |
05-26-2014, 05:19 PM | #2 | |
Kind of a big deal
300
Rep 1,674
Drives: an 1M not often enough
- For any volume buy, it's too bad that the 1M drive shaft is exclusively for our model. - Perhaps related to their usual customers but what I believe is a big benefit to most 1M owners, is not even mentioned: due to the lower rotational mass, centrifugal forces and subsequently over-steer is reduced. |
05-27-2014, 09:16 AM | #3 |
119
Rep 898
Drives: '69 GT3, GT4, 1M, 912
I don't follow. What mechanism are you suggesting that will reduce oversteer?
1M, GT4, 1969 Porsche 911 w/ 997 GT3 Cup Motor (435hp & 2,100 lbs)
05-27-2014, 09:44 AM | #4 | |
Kind of a big deal
300
Rep 1,674
In other words our heavier OEM drive shaft acts as a larger flywheel as any lighter (CF) drive shaft. Once the moment of inertia [kgm^2] (=shaft parameter that quantifies how far away the mass is located related to its axis of rotation) of both shafts is known, the difference can be quantified. At this point I'm not sure whether it will be a significant reduction or not, hopefully we'll get some sense of this either by experience of a pilot buyer or possibly by calculations ... Last edited by eeghie; 05-27-2014 at 10:42 AM.. |
05-27-2014, 12:57 PM | #5 | |
119
Rep 898
I don't believe a change would have any noticeable effect on handling balance, and I can probably do some math to prove that. First consider that inertia goes to the square of the radius, so a 2" diameter driveshaft is going to have ~1% of the inertial effect of a 20" diameter flywheel of the same weight. And you don't hear about lighter flywheels making cars oversteer less. Second I'm not convinced that even if it was much heavier it would increase oversteer. Yes it will increase tire loading when the car tries to change direction, but it will apply that loading to both the front and rear equally, meaning the car would be slower to turn in rather than prone to oversteer. When the flywheel effect gets big you do start to see handling issues stemming from the fact that a right turn loads the tires differently than a left turn. This is seen in Hybrid race cars, such as Audi's Le Mans racer, that use flywheels to store electric energy. However they are likely using something on the order of a ~20 kg, ~10" flywheel spinning at ~50,000 rpm, and with the weight concentrated on the perimeter. Something like this would probably have something approaching 5000 times the rotational inertia of our driveshafts, at which point in their much lighter cars they do begin to see effects on handling. I'll also mention that the driveshaft mass is located low and in the center of the car, one of the last places you want to lose weight. I'd do a lightweight flywheel/ clutch or wheels before I did a carbon driveshaft from a performance perspective.
05-27-2014, 05:47 PM | #6 | |
Kind of a big deal
300
Rep 1,674
05-27-2014, 06:03 PM | #7 | |
European Editor
10589
Rep 22,992
Since the F8x uses a heavily mod'd N55 engine... I wonder IF the factory cf driveshaft could be a direct bolt in. ? I wonder who will be the first to find out.
05-27-2014, 06:12 PM | #8 |
119
Rep 898
The 6" difference in wheelbase makes that very unlikely IMHO.
05-27-2014, 06:17 PM | #9 | |
121
Rep 1,555
On a side note, on one of my previous cars, I replaced the driveshaft from the steel version to aluminium, and could definitely feel the difference on acceleration.
2011 E82 1M VO
2013 F84 35i VO |
05-27-2014, 06:46 PM | #10 | |
European Editor
10589
Rep 22,992
Yes, I know the wheel base is longer. What I meant was that the ends might be the same. I was wondering if one could cut the "difference" out of the M4/M3 part and somehow glue it back together. ? Or have a new customer cf tube made up. Just thinking out loud.
05-27-2014, 07:52 PM | #11 | |
119
Rep 898
The whole thing might save what, 10 lbs? Easily over $100 per pound. Fitting those new carbon brakes might be a better option.
05-28-2014, 09:20 PM | #12 |
384
Rep 3,450
i'm in.
"Well, there's a straight-six engine at the front, a manual gearbox in the middle and drive goes to the back. That's Page 1, Chapter 1 from the petrosexual handbook" - JC
