KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-02-2007, 11:57 AM | #1 |
8
Rep 86
Winter tyres
I will receive my M3 in february ... cold season, and i want to put winter tyres / rim.
Any feedback on which tyres (size, prices, handling ....) i can choose. On my previous E60, i had 17' wheels, but i'm not sure it is possible to put 17' rim on an M3. Thanks in advance |
12-02-2007, 12:12 PM | #2 |
37
Rep 926
Drives: e92 M3 6MT
http://www.m3post.com/forums/showthr...hlight=m3+snow
Try that thread. He has winter tires on his M3. Hope that helps.
2008 e92 M3 6MT AW/BLACK (SOLD) 2009 e92 M3 6MT AW/FR |
12-02-2007, 01:47 PM | #3 |
8
Rep 86
thanks for the link.
Pretty strange, the owner has put 245/40/18 both on front and rear wheels. Stock 18' has the following size : 245/40/18 & 265/40/18. Should we not keep the same difference between front and rear wheels ?? He has noticed that dsc is flashing all the times with its config. |
12-03-2007, 01:15 AM | #4 |
401
Rep 3,288
Wider tires perform worse in snow since the larger surface area of the tire reduces its ability to cut in and create traction. In most cases when you get winter tires they don't come in 8" widths, 7" is the largest I've seen. His DSC is flashing because his BMW is RWD and he has wider tires there.
It's always possible to put a smaller rim diameter on your car, you just need tires with thicker walls to accommodate. If your 17" rims are 5 lugnut designed and not some crazy offset I bet they will work fine. Just so you know, in the tire dimensions the convention is: Tire tread width / wall height / rim diameter |
12-03-2007, 08:32 AM | #5 |
8
Rep 86
thanks for you answer ultimate, but i'm not sure this is correct.
Tyre sizes is expressed like this i think : tyre tread width (expressed in millimeters) / wall height (expressed in % of the tyre width) / rim diameter (expressed in inches) so the front wheel of the M3 does not have the same size of the rear wheel. In the set used by the M3 owner in the post above, he has choosen the same wheels for front and rear wheel -> this is why the DSC is flashing all the time, as it has been configured for 2 different size of wheels. Can anybody correct me if i'm wrong ? |
12-03-2007, 10:04 AM | #6 |
18
Rep 230
Thooooorgal, are you buying your winter tyres straight from BMW or somewhere else in Luxembourg (Goedert for ex) for your M3 ? As far as I know, the BMW "winter kit" for M3 is not yet available and we have exactly the same problem, our M3 should arrive on the 3rd week of January and I don't really want to drive it without winter tyres, specially if there's snow/ice.
12-03-2007, 10:32 AM | #7 |
8
Rep 86
Hi bastet,
the world is small ^^ i'm looking for the best bargain for the tyres, surely after-markets one. Do not hesitate to post here the config you will find. (size, price, ...) |
12-03-2007, 12:01 PM | #8 |
18
Rep 230
Indeed . We'll keep you posted about the tyres. Our BMW dealer at Esch sur Alzette gave us an estimation for the tyres + rims (around 1800 €), but I'd really like to see the rims, because we wouldn't want anything that doesn't match the glorious all black M3 now, would we ?
12-03-2007, 12:38 PM | #9 |
8
Rep 86
I have seen a white M3 with winter tyres last week in luxembourg. He had exactly the same as the last two pictures of Ilron's M3 in this thread :
http://www.m3post.com/forums/showthr...hlight=m3+snow but i did not check the sizes of the tires |
12-03-2007, 02:28 PM | #10 | |
Moderator / European Editor
1512
Rep 6,754
Best regards, south |
12-03-2007, 04:53 PM | #11 |
8
Rep 86
12-04-2007, 08:31 AM | #12 | |
1512
Rep 6,754
Z4M has 225/40 front and rear, M5/6 have 245/45 front and rear. The same size for front and rear tires is said to be best for winter usage. Best regards, south |
12-11-2007, 08:10 AM | #15 |
18
Rep 230
Thoooooooorgal, this is what I received this morning from BMW:
"L'action pneu hiver est sur du Michelin et les jantes sont les jantes d'origine, comme sur votre commande. Le prix est de 2400€ttc". I have asked them to confirm me the exact type of Michelin tyres as well as the exact size. Then we can go hunting somewhere else... |
12-11-2007, 11:53 AM | #16 | |
8
Rep 86
EUR 2'400 i will look in aftermarket winter wheels ^^ |
12-11-2007, 12:07 PM | #17 |
18
Rep 230
No probs. The price at BMW is ridiculous though ! :sad0147: We'll keep you posted on what else is on offer in Luxembourg. And please post info if you find something else
12-12-2007, 06:30 AM | #18 |
18
Rep 230
Thoooooorgal - here's more info about the tyres
Les pneus sont des M+S Michelin Alpin PA3 235/40R18 95V Les jantes sont les Doppelspeiche 270M |
12-30-2007, 09:49 AM | #21 |
7
Rep 109
12-30-2007, 09:56 AM | #22 |
Reincarnated
245
Rep 4,227
I assume those wheels already existed? What about them makes BMW recommend them for winter duty?
