05-24-2014, 04:57 PM | #1 |
Newbie
Rep 68
Cobb AP troubles
Hey guys,
So my Cobb AP V3 came in today. Pretty cool little tool btw While I wait for the long weekend to finish to start the PTF eTune, I figured maybe some of you with more experience can help a fellow 1addict out First, does anyone know if I can use the stage2+ maps with a Akrapovic Titanium Evo set up? The info on the map says Turbo back - is the akra Turbo back or cat back? Secondly, Im getting some codes that just won't go away. On Stage 1 Maps, I get a P2FA3 code, and on Stage 2+ I get P240A, both of which go away when i alternate between the maps (i.e. each sticks to its own map) - these Im not too worried about. However, no matter what map I put on, I get the P2A18 code (DMTL, heating control). From the only info I could find on some forums via google, it seems that this has something to do with emissions, and that it doesn't affect anything else. I honestly don't feel anything wrong with the performance, but that check engine light comes on every time. Any ideas regarding the codes? And should I not be using Stage 2+ if I'm on an akra eve set up?
AW 1 ///M
Exterior: Manhart CF Hood, Trunk, Rear Diffuser, Angel Eyes, CF Side Mirrors Interior: Manhart CF Full Upgrade, Awron Gauge, UUC EVO3 SSK, BMWP Flat-bottom Alcantara Wheel. Performance: Manhart Stage 4 Tune (+ CF Airbox, FMIC, Oil Cooler), Akra Titanium Full Exhaust + cat delete, Manhart Headers, cp-e CP, HKS BOV, Quaife Helical Diff, CDV Delete. |
05-25-2014, 12:01 AM | #2 |
20
Rep 325
Do you have downpipes? If not you should only run a stage 1 map.
Typically stage 1 is just an Ap Stage 2 is downpipes with ap Stage 2+ is downpipes, fmic and ap. |
