05-22-2014, 02:14 PM | #1 |
86
Rep 623
Help me with alignment specs
I need to keep my 08 E90 M3 alignment specs within factory range to be legal to register here in Hawaii. I found the following factory specs in the attachment here on the forum but there's quite a range in those specs. I was curious if someone could help me with where within that range i should be for aggressive street driving. If i'm not mistaken, i would probably want as much camber as possible with as little toe as possible? Is this correct?
05-22-2014, 02:55 PM | #2 | |
68
Rep 869
You have a pretty broad "stock" range there. Pull the front alignment pins and you might get to the upper limit of -1.5*. The rear camber upper limit says its -2.0*. The E9xs don't need huge rear camber, and for the street I'd put it -1.5 to match the front. (I go -2.5*F w/ camber plates and -2.0*R and no probs w/ tire wear on street). Set the rear toe to 1/16" in and front to either neutral toe or 1/16" toe in. Other folks may have different thoughts but this works well for me and should keep you in spec.
2008 M3 Coupe / DCT // StopTech BBK 380/355 / Pagid RS29 / Motul / Apex Arc-8 / BFG R1S / Ground Control / MS filter / Performance spoiler / BPM tune // Road Atlanta 1:39.70 / VIR Full 2:10.87 / Barber 1:42.20 |
05-22-2014, 03:16 PM | #3 | |
2512
Rep 4,381
05-22-2014, 03:45 PM | #4 |
86
Rep 623
Thanks folks.
Yep. Here in Hawaii we need a Vehicle safety inspection to get a registration. To pass vehicle inspection with a modified vehicle, we need to get a Reconstruction permit. Reconstruction permit will need alignment numbers within factory spec. |
