05-22-2014, 05:17 AM | #1 |
11
Rep 72
Recaro pole position installation
Hi guys i want to install racing seats Recaro pole position FIA on my 1M, just bought side mount recaro (7207000), tell me please what means ABE Adapter on this side mount? and i dont understand how to install stok 3 point belts to this seats. don't want to drill any holes, just bolt on
05-22-2014, 12:14 PM | #2 | |
2286
Rep 12,565
Drives: Z4 M, X5, GX460
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.24] |
Seat Side Mount Floor mount Seat belt receptacle adapter Sliders (optional) Side mount shims (optional) 1. Unbolt factory seat. 2. Install floor mounts. 3. Attach side mount to seat. 4. Install seat belt receptacle underneath side mounts. These adapters will get sandwiched in between side mount and floor mounts. 5. If you wish, you can also install optional sliders. 6. Bolt up factory belt to floor mount. Bolt up seat belt receptacle to receptacle bracket. 7. Take assembled seat (with side mount, receptacle adapter and slider) and line it up on the floor mount. It will take a few tries because you need to balance: a) is seat centered with steering wheel, b) will the door close without rubbing seats, and c) will the seat slide up/down ok. To avoid the seat rubbing against doors, you want to go furtherst inboard (towards the trans tunnel / shifter). But if you go TOO close on the trans tunnel, the seat belt receptacle might catch against the trans tunnel preventing you from sliding seat full length. But from experience, going furthest in is better since rubbing the door panel sucks and it'll keep you most centered with the steering wheel. Also, you want to use this time to figure out how to angle the seat. I first installed seat at 90* and I found it to be very uncomfortable over long drive. My lower back would get tired from sitting too upright. I changed it to have front high and rear low, and this provides most comfort and support. It also feels good even when driving on track! 8. To help center the seat by TINY increments without moving over on the next set of holes on floor mounts, you can use shims in between seat and side mounts. See here. 9. FYI - Recaro offers 2 side mounts for Pole Position. One is SPECIFIC to Pole Position, one is UNIVERSAL. Both will work. Difference is UNIVERSAL one will NOT let you move far back. I think the Pole Position specific side mounts gives most room. 10. Figure out how to code airbag light. Should only be issue if you are replacing passenger seat too but driver side alone should not trigger anything. EAS has a DIY video on YT, very helpful. Be sure to watch it few times before attempting install. And remember to add loctite on the bolts. Last edited by 3002 tii; 05-23-2014 at 09:04 PM.. |
05-23-2014, 04:36 AM | #3 |
11
Rep 72
Huge thank 3002 tii for a very helpful answer, i will write mail to machtschnell and ask them can they send it (shipping) to me. From the list what you write I have only
1. Seat 2. Side Mount recaro (7207000). Last edited by 1mPanda; 05-23-2014 at 04:44 AM.. |
05-23-2014, 08:56 PM | #4 | |
2286
Rep 12,565
Seems like you need to buy few more things, unfortunately for BMW seat hardware is VERY expensive. If you buy new, it all adds up almost same price as a cheaper seat lol. Btw Macht Schnell was only 1 example. Like I said, VAC also sells hardware and you should also look up company called Planted. Planted makes good hardware for E46, not sure if they have anything for E8/9x. Also there's a vendor who came up with a new floor mount design that is user friendly. Link here: http://motionmotorsport.net/products...nojeshjtaqpbmz Lastly if you decide to go with MS or Vac, you should look for used parts on forums. These 2 are most popular brands so it shouldn't be difficult finding them cheap. I know I've seen some parts listed in the last few months here, m3forum, e46fanatics, bimmerforums and bimmerfest. Be sure to check both interior and race part classified sections. Here's a picture of my Recaro's in my Z4 =) Picture taken by cage builder Final product! |
05-24-2014, 06:02 AM | #5 | |
11
Rep 72
I order this one 1.https://www.machtschnell.com/www.mac...-seats-e82-e9x 2.https://www.machtschnell.com/www.mac...t-floor-mounts But on the forum I found a bit different mounts, link http://img403.imageshack.us/img403/7...1280x86613.jpg Need to order this bolts? https://www.machtschnell.com/www.mac...lignment-shims want to be sure that i order all what I need |
05-24-2014, 06:31 AM | #6 | |
2286
Rep 12,565
05-24-2014, 07:06 AM | #7 | |
11
Rep 72
05-24-2014, 09:39 AM | #8 |
2286
Rep 12,565
Hard to tell from pics but I'm sure you'll figure it out once all the parts are in front of you. Else call EAS or MS but the install is fairly straightforward. The hardest part is positioning the seat on the floor mounts.
Edit - took a look at the new brackets, seems like you bolt them vertically onto ge floor mounts. |
06-28-2014, 02:58 PM | #9 |
11
Rep 72
just came my part from machtschnell, spend all day to fit it properly, but all attempts were hopeless the parts not fit well together
I bought machtschnell this parts, 1. http://www.machtschnell.com/www.mach...t-floor-mounts 2. http://www.machtschnell.com/www.mach...-seats-e82-e9x also I have universal recaro running rails universal recaro side mouth the harness bracket i can fit only in internal holes, but on running rails no external holes do not fit together with Floor Mounts also Last edited by 1mPanda; 06-28-2014 at 03:04 PM.. |
