05-06-2014, 11:43 AM | #1 |
13
Rep 109
Coilover VS Sleeve
After reading online and some posts everywhere, I still have few questions regards to this.
1. What are the main differences between these two? Most of people are just saying that sleeve can have better ride and if you are not going to track, Coil is not much needed. 2. Just like short springs, but sleeve is a lot less harm for the shocks. How soon will the shocks getting bad and if need replacement, should I go for a softer Coilover (3-5k springs)? 3. What will be the best set up for sleeve? I just bought the car with KW sleeve. Is there a way to pair with camber plates or just stay with OEM shocks? If I am wrong for some of the ideas please let me know. Thanks! |
05-06-2014, 11:57 AM | #2 | |
1892
Rep 5,508
Coilovers are much better as the spring and shock are matched. You can also maintain shock travel at a lowered height without premature wear on the shocks. Also, coilovers have much better performance as it removes the stock shocks which are inadequate to handle any spring rate other than stock springs.
Auto Detailing Enthusiast!
05-06-2014, 12:00 PM | #3 | |
13
Rep 109
I guess I will go for coil after the shocks are going bad. Thanks! PS. I will have a set of KW sleeve over FS really soon! lol |
05-06-2014, 12:01 PM | #4 |
Apex Everything!
983
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
Ride quality on a good (and properly set up) set of coil overs is much better than OEM, IMO.
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
05-06-2014, 12:12 PM | #5 |
13
Rep 109
05-06-2014, 12:14 PM | #6 |
11818
Rep 23,187
yes it is, very good for street car.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-06-2014, 01:31 PM | #7 |
Gone Fishin’
7318
Rep 12,125
I have to disagree. Recently went from OEM Comp pack to KW V3 and I think the ride is a good bit worse. Seems very bouncy almost like when I had H&R Sport on my old car. I had them installed professionally. I then had the car corner balanced and aligned by one of the best shops around.
05-06-2014, 01:41 PM | #8 |
11818
Rep 23,187
kw arent really that great is more the problem i would think.
05-06-2014, 01:48 PM | #9 |
Gone Fishin’
7318
Rep 12,125
KW V3 is by far what most of the coil-over guys run on these cars. If a 3k price tag isn't enough for them to be great well I dunno lol. I have actually considered putting my comp pack suspension back on already.
05-06-2014, 01:51 PM | #10 | |
Apex Everything!
983
Rep 4,378
05-06-2014, 01:53 PM | #11 | |
Gone Fishin’
7318
Rep 12,125
05-06-2014, 01:56 PM | #12 |
Apex Everything!
983
Rep 4,378
Might have to adjust your rebound setting? 2 way adjustments were always frustrating for me to figure out. One of the best parts about upgrading to the Ohlins was the single adjustment valve. Makes things so much more simple.
05-06-2014, 01:59 PM | #13 | |
Gone Fishin’
7318
Rep 12,125
I'm mostly a street guy so Ohlins seem overkill |
05-06-2014, 02:29 PM | #14 |
158
Rep 595
This!
2017 M2 Coupe Black Sapphire Metallic
05-06-2014, 04:52 PM | #15 | |
13
Rep 109
I do see people talk about the problem on the V3, but what would a better brand to go to or just get a cheap one for DD, right? |
05-06-2014, 04:59 PM | #16 |
13
Rep 109
I never had sleeve on before, just want to try out this time. If I dont like it, I will go for Coil. I will not change any settings from what I order. Since I will have softer spring with the right height of the car.
Regards to bouncy ride, I think most time I will do is keep the way factory recommended. Also, I will not go for and spring rate lower than 3K and higher than 7k. Too soft or too hard. Usually, as my exp. I will go for 3k spring and compress about inch to inch and half and make it more like 4-4.5K front and 4K for rear with minimal drop. At the same time, camber adjust to -2 or less to save some tires and better ride for local road. |
05-06-2014, 05:14 PM | #17 | |
1892
Rep 5,508
Also, spring rates are different for different cars so you can't say spring rates within a certain range work for all cars.
05-06-2014, 07:30 PM | #18 | |
13
Rep 109
As what I was trying to say is, find the best set up for personal interest and pick out the right range to go with the car. Not just going crazy or do all the adjustment after buying. This is why I am asking questions here as well. I just want to make sure I have the right set up before buying and make it the best set up after buying. This can make sure the car rides good and the parts less longer. Please correct me if I am wrong. Good point. Thanks man! |
05-06-2014, 07:32 PM | #19 |
13
Rep 109
Another thing regards to this is, I have been in a KW comfort on 335 before and it is really nice ride, but they dont make this one for M3 as my knowledge.
05-06-2014, 07:45 PM | #20 | |
1892
Rep 5,508
http://www.kwsuspensions.com/en/prod...64f81dfe38e8bc
05-06-2014, 07:53 PM | #21 | |
13
Rep 109
