M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > BMW M5 (F10) General Forum
Closed Thread
      05-04-2014, 06:47 AM   #1
JLu
Drives: M5
Beat up by ZL1! So mad!!!!!
Can anyone teach me how to start my 2013 M5 real fast? I just got beat up by a Camaron ZL1 on the street today. I adjusted everything into sport plus with auto shift, traction control on. But then, it beat me after I reached 40mph.
After I got beat up by ZL1, I went back and practiced starting during the night (safely). However, I noticed the rmp at the first gear will stuck at 3000~4000 for like 0.6 sec then rise when the traction control was on. Obviously it slowed down the car from starting off. I turned off the traction control, which the shifting became much smoother but the car was wiggling so badly. I got scared afterward, so I turned off immediately.
Is there any other method that allows me to start off my m5 like a beast and also remain stable???
      05-04-2014, 08:05 AM   #2
Mscarpa
Mscarpa's Avatar
Drives: 2014 M5 Black on black!
Shit, that sucks. That car has some muscle though. I know what you mean about 1st gear which is why I use manual sometimes. Here are the specs on the Zl1, no pussy cat. I would be curious on what our bros say on this matter.
It’s the most technologically advanced Camaro ever. With a 6.2L supercharged engine it delivers an impressive 580 horsepower16 and 556 lb.-ft. of torque. The kind of high-tech power that punches the 0–60 clock in just 3.9 seconds.
      05-04-2014, 08:34 AM   #3
boots
Curve Thrasher
boots's Avatar
623
Drives: 2013 Bmw m5..White/Blk.
Don't know how that happened. My bro here beat that same car w no probs
      05-04-2014, 08:36 AM   #4
PhilT3
6'0 / 250lb
PhilT3's Avatar
Drives: 2014 M5
More HP and less weight... Why SHOULDN'T the ZL1 give an M5 a run for its money?
Build: '14 M5 - Space Gray / Full Sakhir Orange / Alum Trace / Black 343's / Exec / Driver Assist / LED
Mods: SunTek CXP tint - Vinyl-wrapped door handle chrome - Macht Schnell 12mm spacers - Pedalhaus pedals - iND Cosmetic Package - Polished 90mm exh tips - Coded by v12 - 21" HRE S107's polished lip/black center
      05-04-2014, 09:31 AM   #5
Tom C
45
Drives: M8 GC Comp, Shelby GT500
The LSA engine may be rated higher than the S63TU, but in reality the S63TU produces much more hp. My old CTS-V's LSA (mated to an auto tranny) put down 463rwhp on a Dynojet dyno. That was on par with most other stock automatic CTS-V. The manual cars would putting down closer to 500whp. The LSA is rated at 556hp at the crank in the CTS-V and 580hp in the ZL1. So even if the ZL1 is a manual putting down say 500whp, it still weighs early 4,100lbs. If the ZL1 has an auto, it will probably put down under 500whp but probably be faster in the real world than a manual car where time will be lost in the shifts. The average DCT equipped M5 will have a better real world power to weight ratio and much more efficient shifting.
      05-04-2014, 09:43 AM   #6
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
The reason you saw RPM stuck is because of DSC took action.
At hard acceleration, your wheels start spinning and car is becoming unstable. In order to avoid this, DSC takes action, applies brake and cuts the engine. your car moves forward and then DSC releases the power and disengages the brakes and let car go smoothly.
When you turn the traction on (MDM) you give DSC some freedom to put down more power and torque and that's why you felt wiggling.
when you turn off the DSC completely, then it is the deal between Man and machine and you have to control the car by yourself without any help of ECU. Anyways, I believe M5 can beat ZL1 but you need some experiences. I recommend you to go to BMW Performance driving school if you are interested in having some skills. Don't follow people experiences since this car is so powerful and you can easily lose the control.
Goodluck
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT
Gone : 2016 F82 Austin Yellow M4 - 6MT
Gone : 2013 F13 Sakhir Orange M6 -7DCT
Gone: 2013 F13 Alpine White 650i -ZF8
      05-04-2014, 09:51 AM   #7
Hoopumpers
Hoopumpers's Avatar
114
Drives: M2 Comp
73 911 RSR  [0.00]
04 996 Cup  [0.00]
06 997 Cup  [0.00]
12 Boxster Spyder ( ...  [0.00]
15 Sierra HD Denali  [0.00]
16 GT3RS  [0.00]
17 Radical SR3  [0.00]
18 Model X  [0.00]
18 GT350R  [0.00]
19 M2 Comp  [0.00]
- Get your tires warm
- DSC off
- Learn to modulate throttle
- Some prefer comfort suspension
- Don't crash
      05-04-2014, 10:27 AM   #8
mstmng
United Kingdom
141
Drives: M5 F10
man, i loose first 50 meters from red light to black cabs sometimes, spinning wheels without moving at all but i am getting better
i use Sport+ throttle, MDM/DSC off (depending on road conditions), S3
      05-04-2014, 12:21 PM   #9
wisesoul
Savoir Faire
wisesoul's Avatar
Philippines
74
Drives: 2013 BMW M5
Suspension in comfort, everything else sport plus, DSC off. I embarassed a ZL1 using Launch control, albeit looking like a complete tool for using it lol
Current: Alpine White F10 M5|H&R springs|12mm/10mm spacers|Eisenmann Race
Sold:Imola Yellow RS4-KW V3|MTM 10mm spacers|Hotchkis rear sway bar|APR Stage 1|Milltek Catless|RNS-E|Euro RS4 Flat bottom Steering Wheel
Sold:E46 323i
      05-04-2014, 12:32 PM   #10
Actor
Actor's Avatar
10
Drives: a lot!
Black cab??? Hand in your man card!
      05-04-2014, 12:42 PM   #11
M5Rlz
249
Drives: R8, f10m59(Rip), m4, GTR
I was trying to get one to do a 40 roll with me today and post it... He won't come out... I haven't seen any good stock dynos from that car and I'm guessing you lost due to throttle modulation, which our cars should get off the line faster than that thing..
Goodluck
I think MDM is pretty easy to correct for most people in a straight line... Now DSC OFF completely then its a crapshoot haha
If he had full traction on and put it in D mode and mashed lol and the ZL1 driver knew his car even a tad bit.. I can see him losing.
OP DO NOT JUST GO STRAIGHT TO TRACTION OFF... I learned traction off on my M3 and even that was a handful lol I couldn't imagine trying to learn it on the fly on this car. If you're getting scared work with MDM in safe ares where you can't mess up too bad [or get tickets], or head to performance school.
      05-04-2014, 01:30 PM   #12
URBAN LEGEND
Rocky
URBAN LEGEND's Avatar
Drives: 16 M5, 18 ZL1 1LE, 18 M3
Ok. I own both cars.
The ZL1 stock puts out 500 rwhp. A pulley, CAI, and tune brings you to 600+ rwhp. Easily and for about 1800.00.
Stock for stock the ZL1 won't touch the M5.
So I suspect 3 cases here:
1. ZL1 was tuned/pullied/CAI putting out 600+ rwhp.
2. M driver doesn't know car very well yet.
3. 1 and 2.
For the record and stock for stock and in a straight line equals M5 win. On a road course ZL1 wins all day.
      05-04-2014, 01:50 PM   #13
M6-Coupe
M6-Coupe's Avatar
1125
Drives: F92 M8
You are right MDM is pretty easy to correct in a straight line if the asphalt is hard. On soft asphalt still there is skidding like 3-4 feet which is enough to hit the car next to you. As far as DSC off you referred, M5 is completely different compare to M3 E9X since it has much more power and torque so it needs more experience. For sure you have it but not many people have this experience. It needs time to get used to it
      05-04-2014, 01:56 PM   #14
boots
Curve Thrasher
boots's Avatar
623
It would alot nicer if the m5 lost a few pounds. I know for me, I do feel the weight of the car in the corners, but I ensure that I set my speed and maintain it before apply any exit throttle. The lighter cars like the camero does well against the M. But the M does well against the corvette which is also a lighter car.
2013 Bmw M5-Alpine White/Black-Oem gloss blk powder coated wheels-Expel clear bra-35% tint-Rpi Gtm Exhaust-Rpi Downpipes-Rpi Scoops-Halim Cazimi Performance Tune-KwV3 coilovers
Country run
Closed Thread
