04-06-2014, 05:48 PM | #1 |
#thatsanicemovebro
202
Rep 3,920
Drives: E92 M3 LSB/Black 6MT
Wtf is wrong here (brake question)
Hey all
Been noticing this getting worse... What should i check to see why my discs are not getting fully swept? (AP racing kit with strap drive rotors) I really appreciate any help. I will be calling Stillen on Monday-Tuesday also. It's happening on all corners.... |
04-07-2014, 11:42 AM | #2 |
BimmerPost Supporting Vendor
308
Rep 13,093
Drives: BPMsport 2012 E92 M3
Garage List 2013 Nissan GTR [0.00]
2019 Sierra Denali ... [0.00] 1999 Nissan Silvia [0.00] 1999 Nissan Skyline ... [0.00] 1998 Toyota Supra [0.00] |
1. Were all the parts new when you installed them?
2. Are you sure the pads are the correct model? |
04-07-2014, 11:47 AM | #3 |
732
Rep 3,735
Looks like more of a problem with the caliper, not the rotor. A piston could be stuck. Unless the pads being used are not the correct ones.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
04-07-2014, 01:50 PM | #4 |
#thatsanicemovebro
202
Rep 3,920
Im really doubting that the caliper is a problem because it's on all 4 sides. Also, all the pads were the ones suggested by Stillen...thats ive been running on the street for 2 yrs now
04-07-2014, 08:14 PM | #6 | |
#thatsanicemovebro
202
Rep 3,920
Called Stillen They said it was probably because of unever deposit/wear with the track pads and then it shows up with the street pads. Idk how true that is. May also try to just go do some hard stops and see if it clears up. |
04-08-2014, 08:05 AM | #7 | |
1029
Rep 842
04-12-2014, 06:12 PM | #8 |
#thatsanicemovebro
202
Rep 3,920
So went out did some hard stops. About 10-15 hard stops, but had to stop cuz i'm still on winters. Did not really change anything. Hard braking was also not a problem, no pulling to any side or instability of any sort.
So I went back home and took apart the front right. Here are my findings. Any opinions on best course are appreciated. - pads are flat (they are also about 1000 km new) - pads have rust on them, transferred from the disc - caliper looks good - pistons look good - rust on disc (centrally) is smooth but feels caked on - rust on outside feels like a little lip, like the outside of the disc is slightly thicker (less than a fraction of a mm) - when disc width was measured in the summer i was ~1 mm from max wear i.e. 50% (max wear is 2 mm from new). I am not sure what it is now because I cannot rely on a measurement given this new lip. Time for new discs??? Last edited by GewoW; 04-12-2014 at 06:21 PM.. |
04-12-2014, 07:56 PM | #9 |
856
Rep 1,682
You should really keep your track pads on for a few days of street driving after you visit the track. It's the only way to clear the deposits of the rotors. The street pads never get hot enough to do the job.
04-13-2014, 12:18 AM | #11 |
#thatsanicemovebro
202
Rep 3,920
It is also on both sides of the disk, FYI, and in the same pattern.
04-13-2014, 08:24 PM | #12 |
21132
Rep 20,742
Drives: 2021 911 turbo
As posted in the Montreal thread, I've seen this before. The reason you see a rusted portion on the disc is simply because the pad is not contacting the disc there, Just keep on driving on them, and it will progressively go away. You will need much more than 10-15 stops to get there though .
04-18-2014, 05:27 PM | #13 |
#thatsanicemovebro
202
Rep 3,920
Much improved after a 20 min reg drive around Montreal (ok maybe a few aggressive stops )
So this should clear up. I'll let u guys know if anything comes up! |
