03-05-2014, 10:18 PM | #1 |
Joint Chiefs of Staff
24198
Rep 190,807
Improve Throttle Response Time with the new V3 Pedal Box***Extreme Power House
Pedal Box for 279.99$!!!! Now offering the Pedal Box. Improve response time Adjustable with 4 user programs easy installation fits your driving needs Satisfaction Guaranteed or your money back Explanation The "Throttle Response" curve shows the speed at which an engine responds to the driver's pressing of the accelerator. Deficiencies are evident here, especially at times of strong acceleration. Throttle response has less to do with how much power a vehicle has but rather how long it needs to fully release this power, with petrol engines frequently performing better here than diesel ones in this regard. Usually, a naturally aspirated engine is more powerful than a compressor or a turbocharger, a fact which is however not often noticed as the cars are given different response times by the manufacturer. But even when the same engine types are compared, ultimately a difference in response will be determined, as there are a wide range of factors that influence the response of an engine. The throttle response of a stick-shift or a semi-automatic car can be easily enhanced simply by changing gears – in the case of a small car trying to overtake another car for instance, by moving from 5th to 4th gear. Most vehicles are equipped with a drive-by-wire system. Here, acceleration is achieved by way of an electric signal and not by the familiar Bowden cable, something that most people are not aware of. This system is called ETC or ECM. The problem is that these systems often suffer from a significant signal delay, which the PedalBox can compensate for perfectly. This means that more energy is available to the car once again.
03-11-2014, 09:47 PM | #3 |
24198
Rep 190,807
Bump!
03-14-2014, 10:32 PM | #4 |
24198
Rep 190,807
Bump!
