New Ytest
Sign out
Bimmerpost
Login
BMW E39 5-Series Forum | 5Post.com
Go Back   BMW E39 5-Series Forum | 5Post.com > BMW 5-Series (E39) Forums (1995 - 2003) > General E39 Discussions
      02-11-2014, 10:57 AM   #1
ECSTuning
New Lifetime Replacement Policy
ECSTuning's Avatar
816
Drives: Independent Tuning Specialists
:: ECS Tuning :: ECS Teflon Shifter Bushings and Shifter Rebuild Kits
No matter how smooth your 3 Series runs or how tight your suspension setup is, loose and vague shift action destroys all the confidence you have in your driving. The rebuild kits available at ECS include everything you need to rebuild your shifter assembly, from the bushings and clips to the dowel pin. To improve your shift feel from factory, you may also choose to replace the soft factory rubber with virgin Teflon rod, an advanced formula that contains no fillers or impurities, resulting in a long lasting and extremely precise feel.
E39 540i
Click HERE for your E39 540i ECS Teflon Shifter Bushing Kit
Click HERE for your E39 540i Non M ECS Shifter Rebuild Kit
-featuring ECS Teflon Bushings-
Click HERE for your E39 540i genuine BMW Shifter Rebuild Kit
E39 M5
Click HERE for your E39 M5 ECS Teflon Shifter Bushing Kit
Click HERE for your E39 M5 Non M ECS Shifter Rebuild Kit
Click HERE for your E39 M5 genuine BMW Shifter Rebuild Kit
      03-31-2015, 04:04 PM   #2
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E39 540i Shifter Rebuild Kits
      04-03-2015, 11:14 AM   #3
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E39 M5 Shifter Rebuild Kits
      04-03-2015, 02:39 PM   #4
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E39 i6 Shifter Rebuild Kits
      04-06-2015, 11:51 AM   #5
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E9X 325/328/330 Series Shifter Rebuild Kits
      06-18-2015, 01:07 PM   #6
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E39 540i Short Shift Kit W/ZHP Knob
      06-06-2016, 10:52 AM   #7
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E36 318i/ic/is Shifter Rebuild Kits
Click HERE for your E36 323ic/is Shifter Rebuild Kits
Click HERE for your E36 325i/ic/is Shifter Rebuild Kits
      06-08-2016, 12:06 PM   #8
ECSTuning
ECSTuning's Avatar
816
BMW E36 M3 Shifter Rebuild Kits
      03-03-2017, 02:39 PM   #9
ECSTuning
ECSTuning's Avatar
816
Shifter Rebuild Kits | BMW E9X 335
      03-09-2017, 04:23 PM   #10
ECSTuning
ECSTuning's Avatar
816
      06-23-2017, 01:24 PM   #11
ECSTuning
ECSTuning's Avatar
816
Need the perfect knob to know with your new crispy shifter?
Click HERE for BMW ZHP And Performance Shift Knobs
      09-26-2017, 02:36 PM   #12
ECSTuning
ECSTuning's Avatar
816
Click HERE for your BMW E36 M3 Shifter Rebuild Kits
      09-27-2017, 12:26 PM   #13
ECSTuning
ECSTuning's Avatar
816
Click HERE for your BMW E9X 335i/is (2007-2013) ECS Shifter Rebuild and Upgrade kits
Click HERE for your BMW E9X 335i/is (2007-2013) ECS Shifter Rebuild and Upgrade packages
      09-28-2017, 01:56 PM   #14
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E39 M5 Shifter Rebuild and Upgrade Kits
      09-29-2017, 03:37 PM   #15
ECSTuning
ECSTuning's Avatar
816
Click HERE for your BMW E39 525i (2000-2003) ECS shifter rebuild and upgrade kits!
Click HERE for your BMW E39 528i (1997-2003) ECS shifter rebuild and upgrade kits!
Click HERE for your BMW E39 530i (2000-2003) ECS shifter rebuild and upgrade kits!
Click HERE for your BMW E39 540i (1997-2003) ECS shifter rebuild and upgrade kits!
      10-03-2017, 03:26 PM   #16
ECSTuning
ECSTuning's Avatar
816
Click HERE for your BMW E30 318i/is (1984-85 & 1990-1991) Shifter Rebuild and Upgrade Kits
Click HERE for your BMW E30 325/i/is (1984-1991) Shifter Rebuild and Upgrade Kits
Click HERE for your BMW E30 325e/es (1984-1987) Shifter Rebuild and Upgrade Kits
      10-05-2017, 03:23 PM   #17
ECSTuning
ECSTuning's Avatar
816
Click HERE for your E36 318i/ic/is Shifter Rebuild and Performance Upgrade Kits
Click HERE for your E36 323ic/is Shifter Rebuild and Performance Upgrade Kits
Click HERE for your E36 325i/ic/is Shifter Rebuild and Performance Upgrade Kits
5post
