      02-04-2014, 05:18 AM   #1
arthurtwp
arthurtwp's Avatar
Australia
36
Drives: '12 1 Series M '17 M3 Comp DCT
E87 tail light change
Hey guys, so sorry. But I looked for yonks and could not find an answer.
Have an E87 130i pre LCI.
Picked up a plug and play LED tail light from Mars Performance. Was hoping to do the swap myself as have spent a reasonable amount recently doing a SSK install.
Anyone knows where I could find a guide?
      02-04-2014, 06:08 AM   #2
Curare86
57
Drives: 135i
I will be back next weekend if you want a hand
      02-04-2014, 06:14 AM   #3
arthurtwp
arthurtwp's Avatar
Australia
36
Haha Simon, sent you a msg on Facebook.
      02-04-2014, 06:24 AM   #4
flinchy
126
Drives: E82 135i
i'm sure i found a guide last time i did it, can't seem to now
it's super straight forwards
basically:
open the boot
remove the black lip trim piece that's directly in the middle
lay the seats flat
remove the false floor tray thing
undo everything attached to the trim (the black plastic trim around the baby seat mount etc.)
pull the trim off
then the tail light has 3 bolts, 8mm socket IIRC.
      02-04-2014, 06:32 AM   #5
arthurtwp
arthurtwp's Avatar
Australia
36
Whoa Flinchy, cheers man. Gotta go see I need to get the interior removal tool then I guess? and the 8mm socket tool thing, jus raided the toolbox.. don't have it. haha
      02-04-2014, 06:37 AM   #6
flinchy
126
Drives: E82 135i
interior removal tool?
.. hands? :P.. (i take it you mean the plug remover? something slim and flat, or good fingernails, work well unless you have one easy and cheap to purchase)
oh, yeah, and um... hold on i'll go check..
the black plastic bit that goes with the seat mount requires a T40 torx bit/tool of some sort (supercheap should have them, or any reasonable hardware store)
once that's out though, the trim just pulls out (sorta.. wedged in)
you CAN do it without fully removing the trim.. but it's (for the E87) a bit harder... i've done it, not worth the twisting and swearing and you'll lose one of the nuts and have to take it off anyway.
and **important** if you don't make sure the surface the rubber gasket bit is going back on is perfectly clean, and all the nuts are done up completely.. water willl leak in to the drivers side wheel well
if you have PDC, this will make it stop working... (note: happened just before i got the car, PDC died first rain..)
ED: it's similar to http://www.e90post.com/forums/showthread.php?t=4660
except without all the push in clips for the side trims, and without quite as easy access.
if you stick your head in the back and look around a bit with some light, you should be able to see most of what needs doing
      02-04-2014, 07:04 AM   #7
arthurtwp
arthurtwp's Avatar
Australia
36
Haha noted the PDC warning.
:S
Will take extra care. Come tomorrow sunrise will have a look at the regional anatomy and see if I can sort it out.. And get that tool. haha
      02-04-2014, 04:01 PM   #8
JHS130
JHS130's Avatar
Australia
14
Drives: BSM 130i 6MT
2006 BMW 130i  [0.00]
Hi Arthur, here is how I did mine (there is a link to a guide too but in German)
http://www.1addicts.com/forums/showthread.php?t=730693
Please let me know if you have any questions and I'll try to help you out! But be warned: putting the boot lining back in may just make you go crazy
18" 193M | Michelin PS RFT (225/40 F, 255/35 R)| BMWP Intake | BMWP Gloss Black Grille | LCI Blackline LED Tail Lights | LED Licence Plate Lights | CF Wrapped Trim | BMS Clutch Stop | Resonator Delete + Flapper Mod
      02-04-2014, 04:35 PM   #9
flinchy
126
Drives: E82 135i
did you actually find out what CODING has to be done?
the whole swap confuses me.. you have to tap a wire off the number plate lights to light up the LED strips?
but you also have to code it for... something??
      02-04-2014, 05:40 PM   #10
arthurtwp
arthurtwp's Avatar
Australia
36
Haha. Thanks eh. I saw that guide earlier and the whole wiring thing confuses me too.
Actually copped out and bought a direct plug and play. Dont think its as pretty as the LCI ones but at least its not halogen.
http://pages.ebay.com/link/?nav=item...d=151116654658
      02-04-2014, 05:51 PM   #11
arthurtwp
arthurtwp's Avatar
Australia
36
basically:
open the boot
lay the seats flat
pull the trim off
By the way. Love you first step there flinchy
      02-04-2014, 11:13 PM   #12
flinchy
126
Drives: E82 135i
can never be too thorough hah
it was more to keep the frame of reference direct :P
