      02-02-2014, 02:39 AM   #1
a7med606
a7med606's Avatar
Bahrain
41
Drives: 1 ///M + F80 M3
retrofit the sound system
hello everyone
i have a 1m with standard siund system and found a 135i with harman carden sound system ,
i want to exchange from the 135i to put it in the 1m and putting back the standard one into the 135i
which parts exactly should i replace and do i have to code the car ?
can any one help me please
and if photos would be much better
      02-02-2014, 05:55 AM   #2
eeghie
Kind of a big deal
300
Drives: an 1M not often enough
The level of difficulty is hard to access from the information you provided. If you list your (entertainment related) vehicle option list, we might be able to give more specific pointers.
Globally there are 3 sound levels offered on the E82/1M. However the effort involved mostly depends on whether you have any features from factory that have a MOST bus (optical bus for digital audio/video communications like navigation, combox or cd changer). If you don't, I'd suggest considering the Alpine audio retrofit. This is because retrofitting the most bus can be done, but you'd be gutting the driver side and dashboard of both cars to perform this, also you need to be or hire someone with 2 right hands to route the optical wires without destroying them.
You will have to code the car if you change between the OEM audio equipment.
IRC, if you have Hifi audio the bass and door speakers are equal to HK audio. Only the window tweeters and rear shelf speakers have to be switched. If you have base audio then you will also have to re-wire the speaker cables (starting from the driver side trunk iso of the headunit).
Search for 'audio' in the 1M, coupe and DIY sections of forum and some more background info will show up with parts numbers etc.
good luck and do keep us posted along the way.
      02-03-2014, 03:30 AM   #3
a7med606
a7med606's Avatar
Bahrain
41
actualy i dont know which sound system i got but i have cd chabger in the trunk , usb slot and aux under arm rest .
i dont have equalizer setting in the idrive
i only have bass , treble and the sound control front back right and left
the one i saw in the 135
has that equalizer menu and a signature of harmond karden written on the door twitter
      02-03-2014, 04:13 AM   #4
Tab135
18
Drives: My10 BMW 135
It's actually really easy to retro fit logic 7 I have done it in my 135i complete with amp etc, you only require one wire added to your wiring harness.
      02-03-2014, 06:05 AM   #5
eeghie
Kind of a big deal
300
If you have the factory CD-changer then you have a MOST bus and thus have the Professional Radio 663 (Hifi or middle audio level). This is the easiest HK retrofit scenario.
From looking at the schematics (listed as from '07 Sept onwards, depending on the manufacturing date of the vehicles involved, this could be outdated) indeed only the 2 MOST (optical) wires are additional.
Speaker wire colors and routing are the same, but TOP-HiFi/HK has a 20 pin connector and your current HiFi has a 42 pin connector (input output and power supply signals on 1 connector). Those input wires will be obsolete after the switch).
      02-04-2014, 05:49 AM   #6
a7med606
a7med606's Avatar
Bahrain
41
[QUOTE=eeghie;15379846]If you have the factory CD-changer then you have a MOST bus and thus have the Professional Radio 663 (Hifi or middle audio level). This is the easiest HK retrofit scenario.
can you explain to me please ? if you can find a pics or a DIY
      02-04-2014, 11:51 AM   #7
eeghie
Kind of a big deal
300
The '2007-09 onwards' WDS12 schematics that I used for some of the desk research comments above, are attached for the diy rearranging of the speaker and supply pins. For more specific help and confirmation you'd have to specify build date of the involved vehicles and your Vehicle Option (VO) list or VIN.
For a DIY, I think you have to persuade KD135
Good luck
File Type: pdf WDS12 E82 Supply Top-HiFi Amplifier.pdf (114.2 KB, 111 views)
