01-29-2014, 10:35 AM | #1 |
314
Rep 3,675
Omp Wheel Installed...dsc No Longer Works???????????
Ok So I Installed A Omp Race Wheel Last Week....went To Laguna Seca And After Entering The Track I Went To Get On The Throttle And The Dsc Light Began Flashing And I Had No Power....i Immediately Turned Dsc Off And The Car Ran Fine...i Ran All Day W/ Dsc Off....it Forced Me To Really Focus On Throttle Control And I Will Now Always Runs W/ Dsc Off But I Wanted To Know If There Is A Issue With The Dsc Or If Its Related To The Removal Of The Oem Wheel....thank You In Advance
01-29-2014, 11:18 AM | #2 | |
Apex Everything!
983
Rep 4,378
Drives: 2007 Honda S2000, 2017 GT350
2011 E92 M3(Sold). 2007 Honda S2000 (Track Car). 2016 Cayman GT4 (Sold). 2017 Shelby GT350 (AKA Crowd Killer).
My pet project: https://stickershift.com |
01-29-2014, 11:35 AM | #3 |
314
Rep 3,675
lmao....sorry at work and all reports have to be in caps....i forget that the rest of the world uses both lower and upper case....
01-30-2014, 09:28 PM | #4 |
594
Rep 4,488
What are your new wheel and tire sizes? Too large a discrepancy in overall diameter between the front and rear tires can cause DSC issues.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
01-30-2014, 09:35 PM | #6 | |
594
Rep 4,488
If that's not it then yeah DSC could just be doing its job. I just assumed you meant DSC was stepping in under the same conditions that it didn't used to before the wheel swap.
01-31-2014, 12:21 PM | #8 |
314
Rep 3,675
Someone else mentioned the steering angel sensor...at first thought they were messing with me but after speaking with my shop they said the same thing..the dsc is stepping in when any throttle is applied at all cutting all power.... well this is new lmao.... got to love all the electronics on this e92
01-31-2014, 01:29 PM | #10 | |
America
11
Rep 62
-Mid-Ohio-
01-31-2014, 01:49 PM | #11 | |
209
Rep 7,298
01-31-2014, 02:44 PM | #12 |
3663
Rep 3,422
My bad op. I thought you meant dsc was cutting in while out on track, coming out of corners, etc. What you're describing obviously isn't normal.
M4 GTS, GT3, C63 S | E90 M3s, E39 M5
01-31-2014, 03:56 PM | #13 | ||
594
Rep 4,488
DSC uses a steering angle sensor to help it determine where you want the car to go and make the physics-defying adjustments necessary to get you pointed in that direction if you get too far off that path, which is why a incorrectly calibrated sensor can absolutely cause DSC to interfere unnecessarily. UPDATE: Found this procedure over on 1Addicts, worth a shot before paying the dealer considering how simple it is: Quote:
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) Last edited by jphughan; 01-31-2014 at 04:01 PM.. |
01-31-2014, 06:53 PM | #14 |
115
Rep 1,470
keep DSC off and enjoy the car.
radiant - your response had me LMAO.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
02-02-2014, 01:30 PM | #15 |
314
Rep 3,675
looks like this might be the best option
02-06-2014, 09:50 PM | #18 |
915
Rep 3,456
Drives: Harrop E90 M3
Your E46 also had a steering angle sensor, this shouldn't be anything new to you in terms of DSC functionality. As someone else posted, turning the steering wheel lock to lock will calibrate it. If the towering wheel wasn't installed centered correctly, this could be the source of your issue. Count the turns from center to left and right locks. If they're different, there's your answer.
