New 2009 2010 BMW Z4 - ZPOST
Go Back   New 2009 2010 BMW Z4 - ZPOST > BMW Z4 Forum (E89) > E89 Z4 Photos / Video / Media Gallery
      01-14-2014, 01:17 PM   #1
wmandra
Track Addict
wmandra's Avatar
99
Drives: 2010 328i, 2014 Z4
3D-Design gauge pod and Prosport gauges
Installed boost, EGT and AFR gauges in the Z4 today. The 3D-Design gauge pod is excellent in terms of build quality and really matches the OEM look. The gauges are wired up to light amber and match the dash almost perfectly.
Here's a short video of the startup sequence:
Driver, Ratchet Head Racing #93 BMW Z4
Club Organizer, Garden State Euros Motorsport Division
2014 Glacier Silver Z4 28i M Sport - See the build thread: http://e89.zpost.com/forums/showthread.php?t=950367
      01-15-2014, 11:11 AM   #2
Z4-35i
United Kingdom
Drives: Z4 35i
They look good, how complex was the install?
Z4 35i Black Sapphire with Coral Red Leather : Michelin Pilot Super Sports, Eibachs, ESS, LUX Angel Eyes, Carbon Roundels
      01-15-2014, 03:29 PM   #3
wmandra
Track Addict
wmandra's Avatar
99
Install was a breeze once I figured out to to remove the top of the center console without breaking it It just snaps in place, but requires a bit of effort to pull out. I had the smokers package, so I was able to pull +12V and ground for the gauges off of the connector for the cigarette lighter. Running sensor wires into the engine bay also fairly easy as there is a large rubber grommet on the passenger side firewall which is easily accessible once you remove the under-dash cover.
      01-15-2014, 07:31 PM   #4
Hujan
Hujan's Avatar
Drives: M3
I'm not seeing images and the YouTube link appears to be broken. Sounds cool, though.
      01-15-2014, 07:40 PM   #5
wmandra
Track Addict
wmandra's Avatar
99
video link fixed- i think.
      01-16-2014, 12:25 AM   #6
Hujan
Hujan's Avatar
Drives: M3
Yup, that worked. Looks very cool. How easy is it to see the gauges from the driver's seat?
Does every kit come with boost, EGT, and AFR, or can you customize? (I like the idea of boost, EGT, and oil pressure.)
      01-16-2014, 01:57 AM   #7
wmandra
Track Addict
wmandra's Avatar
99
pretty hard to see them when in 3rd or 5th gear to be honest. Its not a kit, you can get the gauge pod from iND and the gauges came from prosport. They have tons of gauges availble so you can pick whichever 52mm ones you want.
      01-17-2014, 02:47 PM   #8
BMWZ4RIDER
BMWZ4Rider
BMWZ4RIDER's Avatar
Drives: 2009 BMW Z4 35i
Do you have to cut into And splice into the OEM wiring harness(s)?
What are the Under the Hood wiring connections?
Cost of the POD with gauges?
Thanx,
2009 BMW Z4 35i/SMG/DCT/Premium,Cold, Sound PK/Com Acc/Ash/PDC/Wind Deflector/Smoked Reflectors/Red Calipers/Cl Mask/M Series Grill/6000K LED's/De-Badged/M Pedals/CF Mirrors-Engine Cover/Stubby/20% Tint/H8 LED's/LCI Side Markers/Sniper Sprint Spoiler/VMR V710/H&R Sport Springs/KN.
      01-17-2014, 02:54 PM   #9
wmandra
Track Addict
wmandra's Avatar
99
Thanx,
Didn't have to cut into any OEM harnesses for power. Under the hood, the sensors for EGT and AFR require separate bungs in the downpipe (I'm using a catless one from EvolutionRaceworks that came with the bungs). For boost I had to tap the charge pipe to install a vacuum hose to pick up boost pressure.
Gauge pod - $362.00
AFR gauge - $224.99
EGT gauage - $93.99
Boost gauge - $54.75
zpost
