KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
12-28-2013, 07:51 AM | #1 |
142
Rep 605
Summer tire sizes - 275/295 or 285/305?
When I get new summer wheels this year I will need new summer tires also. I was planning on getting some 19x10 F and 19x11 R or similar wheels probably Forgestar Superdeep concaves.
Looking at tire sizes. I want to keep close to stock ratios if possible. I had thought 275 F 295 R would be ideal, however after checking the calculator I see 285 F and 305 R is closer to diameter size. Is this setup even possible? I haven't seen many people run it, likely because 285/30s are hard to find or is it because they will rub? Is it even feasible? |
12-29-2013, 09:01 AM | #2 |
2740
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
275's are the maximum in the front. 305's are possible in the rear. Correct offsets will be key for the success of any of your planned sizes.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
12-29-2013, 06:24 PM | #3 |
142
Rep 605
12-29-2013, 06:28 PM | #4 | |
2740
Rep 6,734
'23 X7
12-29-2013, 10:13 PM | #5 |
142
Rep 605
01-02-2014, 03:55 AM | #6 |
38
Rep 303
to fit 275/295 an offset around +22 is ideal on a 9.5/10.5 wheel stagger, and im not sure about on 19s but on 18s 285/305 is totally doable, and why not have more tire if you can :-P
01-02-2014, 08:37 AM | #7 | ||
2740
Rep 6,734
'23 X7
01-02-2014, 01:06 PM | #8 | |
2740
Rep 6,734
22mm offset on a 10.5" wheel with 295's in the rear will rub on the metal fender and camber can not fix the problem... Unless you are lucky and/or run a tire brand that runs narrower than most. 25 mm offset in the rear is the ticket to fit 295's without rubbing on 10.5's. I have tested both offsets with Yokohama AD08 tires. 295's fit with et25 and negative camber. I couldn't get the et22 to stop rubbing on big dips (rub was minor but it hits the painted part of the metal fender).
'23 X7
01-02-2014, 02:10 PM | #9 | |
38
Rep 303
01-02-2014, 02:27 PM | #10 |
2740
Rep 6,734
You are one of the lucky ones
'23 X7
01-05-2014, 11:11 AM | #11 |
142
Rep 605
Ok to summarize: 275/295 19s
9.5/10.5 or 10/11 will work. Is one preferred over the other? 10/11: Et 25 front and et 30 rear. If you add camber you need et17 front. (Will et17 fit without camber? On the same vein - how hard is it to get to -2 camber and can most shops do it?) 9.5/10.5: et22 front and et25 rear Should fit most tires. |
01-05-2014, 01:35 PM | #12 | |
8
Rep 180
The camber would then have to be something like -2.0 otherwise your tire would rub on the fender. - depending on your style of driving, you will notice your tires wear quicker but if you're not being a bone headed fool then not a whole lot quicker! |
01-05-2014, 02:35 PM | #13 | |
142
Rep 605
I'm not going to change the suspension in this car so I'd like something I can fit now and also that will fit when/if I do a camber alignment for more cambers. I have my STI for a car with a stiff suspension I don't need another :P |
01-07-2014, 07:31 AM | #14 |
Putcha ang ganda...
281
Rep 5,441
im running 275 front 19x9.5 22 no issues
rear 305 19x11 33 definately no issues no rubbing. sits very flush even better with PS2's
01-15-2014, 05:36 PM | #15 | |
142
Rep 605
Can I run 19x9.5 and 19x11 with the stock tires as well? I think I'd like to finish out the use on my stock Contis and put off replacing them for a year or so if possible. Will this offset work? |
