12-01-2013, 04:22 PM | #1 |
Rep 27
Registering New Battery
I just installed a new battery in my 2008 M3. Now I need to register it. I got the OBD2 K+DCAN cable, and installed BMW Standard Tools on my netbook running windows 7.
I hook the cable up to the OBD2 port, turn the car on (ignition on, car not running), and start up Toolset 32 (version 3.8.7). I am trying to use the guide below, but when I try and load MSD80.prg, it doesn't load, the computer just has the circling blue circle... I gave up after about 5 minutes or so.... Should this take a long time like this? Am I doing something wrong? Any ideas? Here is the guide I am trying to follow: In that case you open up Toolset 32 (under EDIABAS folder): 1. Open MSD80.prg 2. Look up steuern_batterietausch_registri. (near bottom of job list) 3. Go to Jobs menu 4. Select Run Job (May alternatively be under MSV70 or MSV80.prg) from: http://www.e90post.com/forums/showthread.php?t=532315 Thanks!! -Derron |
12-01-2013, 07:39 PM | #2 | |
Ballin' out of control.
520
Rep 1,289
12-01-2013, 09:49 PM | #3 | ||
Rep 27
Either way, thanks for letting me know, I was wondering which one was correct for the M3, thank you for the clarification! |
12-01-2013, 09:54 PM | #4 | |
Rep 27
Not a lot can be done with it, you can use it to register your new battery, and read and clear codes. But nice and simple, and free :-) I would still like to learn how to use INPA, Toolset 32, and EDIABAS now that I have it, to play around with some other coding, so still would like to figure out what I am doing wrong (other than choosing the wrong log to load).... |
12-02-2013, 09:22 AM | #5 |
520
Rep 1,289
No, the .PRG files are ECU specific descriptors with the jobs for a given ECU. You could try MSS60.PRG instead.
12-02-2013, 10:52 AM | #6 |
829
Rep 3,387
Read over this thread.....BMW Logger is the easiest and cheapest route....
http://www.m3post.com/forums/showthread.php?t=884504 |
