11-25-2013, 09:34 AM | #1 |
9
Rep 88
Stock brakes - dust boot failure
It's November, it's cold, track season is over. Time to swap out my track pads for street pads. I removed the pads and noticed that 3 of the piston dust boots have serious holes in them, and 1 is brittle and cracking but no obvious holes.
The car only has 4 track days on it. I'm confident that all dust boots were in good shape before I installed track pads (PFC 08) in July. My brake temps were 750-800F after sessions. Questions: 1. Should I expect dust boots to fail this fast on stock brakes or is age (5 years) a contributing factor? 2. Rebuild myself or buy remanufactured calipers from Turner? (BBK is not an option) 3. Does anyone sell high temp boots? |
11-25-2013, 12:03 PM | #2 | |
81
Rep 1,510
No experience with the same car doing this, but with the same caliper. My old 335's front dust boots practically disintegrated after a season of heavy track use with DTC70s and PFC01s. I researched route #2 (rebuild kit) but ended up buying a used caliper set from here for ~$100. PS. This year I melted the caliper guide pin threads on that caliper (on the M3) by attempting to swap out pads between sessions - no cooldown. Last edited by mid-corner fun; 11-25-2013 at 12:15 PM.. |
11-25-2013, 01:02 PM | #3 |
37
Rep 381
Get some .05 mm Ti pad insulators for next season from Hardbrakes or somewhere similar. I got a pack of four, used two up front and modified the other two to fit on the rears.
Never a problem since I started using them.
11-25-2013, 03:05 PM | #4 |
594
Rep 4,488
Good call. Fwiw, StopTech Street Performance pads at least for the fitment for their ST-60 BBK caliper come with titanium plates that you can swap onto race pads when you're headed to the track. I can't remember whether the pads in OEM fitment come with them though.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
11-25-2013, 03:55 PM | #5 | |
115
Rep 1,470
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
11-25-2013, 03:57 PM | #6 | |
115
Rep 1,470
11-25-2013, 04:24 PM | #7 |
9
Rep 88
Interesting... Do these work with the clips on the pads or do the clips have to be removed? If they have to be removed, do you get a lot of rattle?
11-25-2013, 08:07 PM | #8 | |
21121
Rep 20,741
Drives: 2021 911 turbo
11-25-2013, 08:56 PM | #9 | |
37
Rep 381
You can use the Ti shims with the clips in place; you just have to finish cutting a precut circle in the shim (for the clip pin) and then a slot toward the top so you could slip it behind the clip. I may do this with my next set of pads.
11-25-2013, 09:10 PM | #10 |
1578
Rep 8,077
Drives: 11 E90 M3 Individual
My dust boots were actually on fire when I came off the track once. Thank god for bottled water!
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
11-25-2013, 09:22 PM | #11 |
37
Rep 381
Why does this not surprise me?
11-25-2013, 09:23 PM | #12 |
1578
Rep 8,077
My dust boots are like me...EN FUEGO!
11-26-2013, 10:18 AM | #13 |
594
Rep 4,488
Interesting, they swap over to my PFC 08s just fine. I'm surprised the pad shape can be that different between two products that are designed to fit into the same caliper....
