11-19-2013, 02:20 PM | #1 |
44
Rep 213
Winter Slumber "The Big Sleep"
Hey guys,
I've put away my 993 and sadly, it's time to put the 1M into hibernation as well. I've looked in the search button, but couldn't find much discussion on winter storage. With the Porsche, I over inflate the tires to 50lbs, put some gas stabilizer in the tank, and then plug in the cigarette lighter battery tickle charger thingy...and that's it until spring. So my question is, what should I do with the 1M? Same thing? Is there a battery tender that anyone recommends? Last year I did nothing and the battery was toast by spring. Had to replace it... Any suggestions would help. Thanks in advance. Susi |
11-19-2013, 04:03 PM | #2 |
103
Rep 1,417
I purchased the, Battery Tender 021-0128 Battery Tender Plus from Amazon, under $50 it works great. Under the hood of the car is a Red plastic covered Positive connector, left rear side of engine above valve cover. Aluminum connector left forward on the fender is the Negative connector.
I don't over inflate the tires, I just fill them to the numbers on the door sill. About 1/3 fill of gasoline and cover my car with the BMW M car cover. If there is a Very good weather day where the roads are totally dry I may take the car out for a little drive, enough to bring the oil temp up to normal readings then park again. Winter sucks.
2011 1M, Valencia Orange, All options.
August 8th ED (#293 of 739 or 740) 88 E30 M3 100% OEM 73K Miles 02 E39 M5 Le Mans Blue 50K Miles 06 E46 M3 ZCP 58K Miles |
11-19-2013, 07:38 PM | #3 | |
44
Rep 213
Thanks Redadair
A battery tender is on the short list. Thanks for the tip, not too difficult of a DIY but a bit more challenging than the cigarette lighter type. Quote:
Thanks again |
11-19-2013, 11:06 PM | #4 |
40
Rep 1,058
Sounds vaguely familiar, except I put my Cayman away today, and put winter tires on my 1M!
The faster you go, the better it feels
11-20-2013, 02:52 AM | #5 | |
Kind of a big deal
301
Rep 1,674
Drives: an 1M not often enough
For remote storage: activate valet switch and lock glove box. Last edited by eeghie; 11-20-2013 at 03:42 AM.. |
11-20-2013, 12:46 PM | #6 | |
103
Rep 1,417
Taking the car out for a drive once or twice in winter when the weather is perfect and the roads are dry helps this flat spot issue.
11-20-2013, 01:02 PM | #7 |
460
Rep 4,531
Modern tires resist flat spots. In my Z4M I go a couple pounds over but in reality it doesn't do anything.
I throw a battery tender on the car (connect straight to the battery in the back) and fill the tank to full to resist condensation. That's about it. |
11-20-2013, 07:31 PM | #9 |
CW2
27
Rep 440
Drives: 1SMC - traded away
I got the flat stoppers from Race Ramps. A little fuel stabiliser, the OEM M cover, and a trickle charger.
I like to still take it out periodically when there's no salt etc. just to get the fluids back in motion and work the brakes, clutch.
Good-bye, ol' Paint...
11-21-2013, 11:31 AM | #10 | |
44
Rep 213
Susi |
11-21-2013, 11:36 AM | #11 | |
44
Rep 213
Suz |
11-21-2013, 05:22 PM | #12 |
1556
Rep 3,235
I put away my 1er too. Extra air, no gas stabilizer and disconnected the negative terminal on the battery.
Before removing the terminal, I rolled the windows down a bit and left the doors unlocked. Placed the cover over it and tucked it away. We never use gas stabilizers, never had any problems. Is it really needed?
2012 BMW 128i 6MT Deep Sea Blue Metallic
11-21-2013, 09:36 PM | #13 |
Rep 52
I think on another thread someone had said that not driving your 1m was like not sleeping with your partner so you can keep them good for their next one...
However i do too store cars but one of them is a Caterham without a heater and i think if i drove that during the winter you can forget about me keeping my wife or any other poor sod happy as my bits would have comprehensively dropped off! |
11-22-2013, 06:20 AM | #14 | |
460
Rep 4,531
As well as flat-stoppers. You'd be amazed at how modern tires resist flat-spotting. I wouldn't lie OP. I've done this for the past 3 years and my tires have been perfectly fine. Just trying to save you money from worthless gimmicks. |
11-22-2013, 06:55 AM | #15 |
4338
Rep 6,196
Highly recommend a fuel stabilizer, especially if you use gas that has ethanol in it, which is 99% of the fuel out there.
Cost me nearly $1000 to fix my bike last year after not using it. Lesson learned. |
11-22-2013, 04:17 PM | #16 |
220
Rep 695
+1
I've had a few cars in long term storage for years (one is an '87 with 5.2k miles), and have never had fuel-related issues. I use Stabil twice a year. Just another data point to consider. |
11-22-2013, 04:43 PM | #17 |
7909
Rep 11,785
