10-29-2013, 09:24 AM | #1 |
140
Rep 1,665
Vortech V3 blower leaking
Anyone else's blower had a leak? I just open the hood and saw there's a bit of oil on it
It's just under 2 years old ess kit (not that it has anything to do with the blower on it) about 35,000kms |
10-29-2013, 11:40 AM | #3 |
34
Rep 454
Drives: :O
If the leak is coming from the breather then that is normal.
10-29-2013, 11:55 AM | #4 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
+1. Mine does this and the oil level is perfect. Vortechs do this. My first one 20 years ago (the old V1 rock grinder) did this as well.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
10-29-2013, 03:21 PM | #5 |
140
Rep 1,665
10-29-2013, 03:51 PM | #7 |
423
Rep 5,329
mine started leaking from the join between the 2 halfs.... unfortunately the unit has a failed internal seal, wheneva it would see boost it would spit its guts out.... luckily mine was covered under the ess warranty and they overnighted me a new unit FOC.
The unit was damaged during a pulley change by my ess approved installer. ive heavily tracked my car and to be honest i can see some "wetness" around the breather but its never sprayed under the hood etc....
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com |
10-29-2013, 03:52 PM | #8 |
532
Rep 5,498
My guess is the breather as well. Its possible you popped a seal but with a vented blower I am not sure how easy it is for that to happen. The next obvious possibility would be that the dip stick is loose or has come loose allowing some fluid to seep.
SC setups on our cars also cause blow by so be sure what your seeing is not engine oil. I found a film of engine oil in and around my blower as well as in my intake the last time I opened up my system.
Instagram: jellismotorwerks |
10-29-2013, 04:25 PM | #9 |
_______
169
Rep 1,088
Just throwing it out there just in case. Did you replace the shipping plug with the breather?
'13 35i M-Sport X3 | JB4 Stage 1 | BMS Intake | H&R Springs | Gloss black grill | CF Wrap and Coded by me | Recaro Child Seats
'15 M3 DCT AW/SO | JB Stage 1 | RKP Diffuser | P3 | M Perf Spoiler | iND Exterior Trim | Recaro Child Seat |
10-29-2013, 06:28 PM | #10 | |
10
Rep 321
you should look into capping the intake and running a catch can/breather setup to eliminate/reduce the blowby |
10-29-2013, 06:54 PM | #11 | |
532
Rep 5,498
In the end, a catch can might be the quickest/easiest solution.
10-30-2013, 12:23 AM | #12 | |
10
Rep 321
