10-28-2013, 07:17 PM | #1 |
137
Rep 455
Need "used" working N54 injector
Long story short, my #4 injector is leaking.. BMW won't even look at them because the car is out of warranty and I guess 3 years ago they looked at it due to the injector service bulletin so they won't look at it again. Just need a used injector that doesn't leak to get me by until I can afford to buy 6 new injectors.
2022 M4 Comp xDrive in Wildberry Metallic
10-28-2013, 08:11 PM | #2 |
European Editor
10589
Rep 22,992
AND.... you will also need to code it once you "find" a used injector. New ones are around $130 per FYI.
Dack
10-28-2013, 08:41 PM | #3 |
137
Rep 455
I have a friend that can code it, I just need the injector! And I was told the new 11 injectors aren't compatible with the 1-10 injectors... and I would have to replace all of them with the new 11's.
10-29-2013, 08:36 AM | #4 |
137
Rep 952
This is true. If you replace with an index of 11 or higher, you need all index 11 injectors. I have 3 decent index 09 injectors and 2 index 05's.. I have no use for them as I have an N55 so let me know if you want one.
13 X1 35iX, 98 Z3 2.8, 01 M Coupe, 96 Z3 1.9 DASC, 95 318ti, 13 smart fortwo
10-29-2013, 10:53 AM | #5 |
42
Rep 159
If you have the older 13537585261 injectors you can still find a few places that have old stock and I believe the index number does not matter for those (Correct me if I'm wrong). That way you could just replace your single bad injector.
I was also told you only have to replace 1 bank at a time with the new 13538616079 injectors. http://www.getbmwparts.com/partlocat...catalogid=4462 $460 for 3 with free shipping |
10-29-2013, 11:02 AM | #7 |
137
Rep 455
Out of the ones you have, what is the least used one? And how much for all 5 of them? I have seen some people selling sets of 6 old used injectors for around 90-100 dollars. If you will let them go for cheap enough I have no issue buying them all and paying for shipping.
