10-17-2013, 04:59 PM | #1 |
10
Rep 358
S65 throttle butterfly and Vanos???
This in regards to a M3 E92 coupe...
I see the cool pictures of our S65 with the 8 individual throttle butterfly valves. However, since BMW has choosen to have almost nothing specific to the M3 nor technical (service manual etc.) ...I am now confused. I have read about Electronic throttle butterfly control: "Electronic throttle butterfly control replaces the mechanical connection between the accelerator pedal and the throttle with an electronic signal. Also known as "drive by wire", this system sends digital information about the position of the accelerator to the central engine management unit." then I came across this........... Valvetronic "This highly advanced technology replaces the conventional throttle butterfly with a electrical mechanism that controls the amount of lift of the individual intake valves on each cylinder. Your engine is able to breathe freely, delivering better performance while using less fuel." "The performance of the engine is more efficient and immediate, thanks to the elimination of the pumping losses and air-flow disturbance caused by a conventional throttle butterfly. Instead, air can flow through the intake manifold freely, and Valvetronic precisely regulates the quantity of air entering the cylinders. " " The throttle butterfly is no longer needed as a means of controlling the air supply - though for safety reasons it is still fitted as an emergency back-up." WTF?? LOL Now I don't get it...? Anyone ...? Are the throttle butterflys electronic? Or are they not used and only there as a backup since we all have double vanos...??? |
10-17-2013, 05:17 PM | #2 |
Bad Lieutenant
233
Rep 3,517
I'd rather have mechanical linkage, over any of the electric throttles. Most of the new BMW engines use valvetronic, however. I wonder how the carbon buildup will affect this mechanism down the road.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
10-17-2013, 05:42 PM | #3 | |
Stop the hate, get a V8
3850
Rep 8,625
Probably won't, as these motors are not direct-injected.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
10-17-2013, 06:03 PM | #4 |
1390
Rep 2,336
Vanos is variable cam timing and valvetronic is variable valve lift. The s65 doesn't have vavletronic only vanos. The throttle butterflys are electric and are used just like a normal throttle would.
10-17-2013, 06:09 PM | #5 | |
10
Rep 358
I guess ill stop reading the BMW web site (since it has nothing M3 specific) ...makes it a waste of time. |
10-17-2013, 07:30 PM | #6 |
Bad Lieutenant
233
Rep 3,517
I'm not speaking of the S65, the newer M3/M4 uses valvetronic, DI, like the N55, N20 and the rest of the turbo lineup.
10-18-2013, 08:51 AM | #7 | |
3850
Rep 8,625
Audi seems to have drastically reduced the buildup on their newer motors (3.0TFSI, 2.0TFSI). They did this with a new and more complex vapor reclamation system. I saw photos of the valves on those cars at 60k and they looked pretty good. I would assume BMW has improved the technology in the newer motors as well.
10-18-2013, 08:21 PM | #8 |
Rep 54
All cars on the road are "drive by wire" aka electric signal from the pedal to the throttle opening so that is nothing unique. The 8 individual butterlies operate the same as a single in terms of the signal from the pedal. The difference and improvement is that air flows all the way to just above the cylinder to reach the throttle body so that when the throttle is opened, the pumping losses are less to get that air into the cylinder and it does it faster so better response. Each side of 4 open at the same time. Basically gives better throttle response and a bit more power.
Valvetronic is even better as the air gets all the way to the valve itself which modulates how much air gets in. That eliminates pumping losses typical lost in the intake plenum/throttle plate to the cylinder |
10-18-2013, 09:41 PM | #9 | |
915
Rep 3,456
Drives: Harrop E90 M3
