10-16-2013, 10:03 AM | #1 |
264
Rep 584
Drives: 2023 M3 CX
Removing the CEL after exhaust...
Sorry for the noob questions but im about to install some Macht Schnell test pipes on my E92 M3 and i know im going to get a CEL. Is there any way to get rid of the light without purchasing some aftermarket tuner software or flash device? Like can i just clear and erase the code for good using a OBD scanner from some auto store?
Thanks in advance!
2023 BG G80 ///M3 COMP XDRIVE Dinan CF Intake | Valvetronic SS Full Exhaust | AST Adjustable Springs | UNIT 17 Front Splitter | UNIT 17 Sideskirts | BC Forged HSC21 Wheels 20x10 et12 / 20x11 et12 |
10-16-2013, 11:25 AM | #2 |
Bored all the time
382
Rep 2,173
no. You'll need a tune or acrapovic delete R
Current: 2014 991 Turbo RS
Past: 15 GT3, 17 R8 SC, Two 16 M4 GTS’s, Two 18 GT350R's, Two 13 RS5’s, 13 M3, 10 R8, 15 M4, 09 M3, 04 M3, 09 S5, 02 M3... It all started with an RX-7 (FD). |
10-16-2013, 01:56 PM | #3 |
201
Rep 4,318
Akra Delete-R (will continuously delete the CEL) or something like the BT tool (have to hook it up every ~100 miles and manually reset it.) I just ignored it for over a year then wound up getting a tune.
GT3 RS | Desperately seeking the next great M car...
10-21-2013, 11:15 AM | #5 |
18
Rep 241
Drives: 2011 E93 M3
I've heard some guys getting thru with it coded out, and some with it coded out they are reporting that it failed the O2 readiness test even though there is not light. I am due to be tested by the 15th of Dec. I think I'm going to have pipes welded to the cats so they can be swapped out easily, switch to a ready file, then switch them back out.
2013 F10 M5/TTFS CUSTOM TUNE/PURE S1 TURBOS/METH/AMS CL DPS/RPI CATBACK/KW SLEEVE OVERS/RPK FRONT LIP/M PERF REAR SPOILER/20" LOMA SUPERTEC SUPERLIGHTS
10-22-2013, 06:07 PM | #6 | |
146
Rep 1,201
Question for others: Does the CEL cause a performance loss?
'08 E90 w/ just boltons
'09 Z4 sDrive35i w/ just boltons |
