10-09-2013, 10:06 AM | #1 |
662
Rep 1,424
broken wheel stud
Last Saturday we were doing a bunch of ride along/joy rides in the E46 M3. It consisted of back to back ride for 1-1.5 hours three times that day. The car rolled into the hot pits and the stud just dropped off the car. It broke inside the hub so will need to be drilled out. The studs were about 1 1/2 yr. old. Just a reminder to replace your studs this winter........we have a full set on order.
10-09-2013, 10:33 AM | #2 |
11818
Rep 23,187
that sucks. good to know. i usually give them 2 seasons but may rethink. i also dont abuse the car like eddie can.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
10-09-2013, 10:49 AM | #3 |
594
Rep 4,488
Thinking about getting studs and heard good things about the durability of Vorshlag's offering. Any personal experiences with theirs? $5.50 per stud definitely ain't cheap, but it's cheap for car mods and obviously this isn't somewhere you skimp. I have their camber plates and have been very happy with them.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
10-09-2013, 11:03 AM | #4 |
Mr. Nice Says Hello
636
Rep 16,662
Drives: BMW M3 | X5 xdrive 35i MSport
good point, going to replace mine this winter as well
10-09-2013, 11:08 AM | #5 | |
108
Rep 697
Bimmerworld usually has studs during their Xmas sale so I make that an annual purchase. |
10-09-2013, 11:50 AM | #6 |
12
Rep 149
I had no idea that this was a regular replacement part!?
Is this only for aftermarket studs or is this recommended for stock ones as well?
ESS VT2 625 | Brembo 380mm F/R | Stack Gauges | Meisterschaft GT | KW V3 | Perf Steering Wheel | Challenge GT Lip | Perf CF Spoiler | CF Mirror Caps Tundra TRD Rock Warrior |
10-09-2013, 12:12 PM | #7 | |
594
Rep 4,488
The stock setup uses lugs, not studs, which are far less likely to break off due to design and the fact that they're not practically cemented into the hole with red LocTite. That stuff grips so tightly that to remove a stud you have to heat it to about 500 F with a torch to melt the LocTite before you have a prayer of getting it out.
10-09-2013, 12:21 PM | #8 | |
12
Rep 149
I thought about getting these http://ind-distribution.com/ind/cate...ugnuts-set-821 to make wheel changes easier but just ended up getting a wheel hanger from ECS. Mo' Mods Mo' Problems
10-09-2013, 02:53 PM | #9 |
120
Rep 937
I too didnt realize extened studs needed to be replaced, let alone every year. I track with stock lugs and was mad I didnt install/buy extended studs.... not any more after reading this.
2009 E93 M3 Sold
10-09-2013, 03:06 PM | #10 |
11818
Rep 23,187
You should be replacing stock bolts as well if tracking the car. Lots of things become wear items once you track including wheels. I have used apex and turner studs.
10-09-2013, 03:56 PM | #11 |
2741
Rep 6,734
Drives: 'E46 M3 Race Car, '23 X7
Yes you are right. I think that a lug that is repeatedly used (when changing wheels for track use) will actually wear out faster than studs.
'23 X7
'04 M3 - Fall Line Motorsports Built Race Car - S65 swap, Dry Sump, Bosch Stand-Alone ECU, Drenth Sequential Trans, MCS 3-Way, Flossmann Wide Body, Brembo Motorsports Brakes, Drexler LSD, BBS E88 Etc. INSTAGRAM - @Slicer_M |
10-09-2013, 03:57 PM | #12 |
120
Rep 937
Very good point. I wonder the replacement interval on stock lugs.
2009 E93 M3 Sold
10-09-2013, 04:06 PM | #13 |
11818
Rep 23,187
10-09-2013, 06:35 PM | #14 |
34
Rep 898
10-09-2013, 06:48 PM | #15 |
1578
Rep 8,077
Drives: 11 E90 M3 Individual
A year is a good guideline to replace lug bolts AND studs. Think about the lateral loads they see on the track.
With that said... Properly installing the studs will help (don't need to torque them down). Properly torqueing lug nuts will help (don't do it when they are hot). I just check for loose studs throughout the day, I don't re-torque (ends up in overtorquing) If you ever drive the car and the wheel was not seated properly against the hub, replace the studs. They will fail much quicker. Funny think about BMWs. If I've ever seen a car with a wheel that comes off at the track...its a BMW. 5 so far. I have never seen another marques lose a wheel. Just my observations.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
10-10-2013, 02:17 PM | #16 |
662
Rep 1,424
Yes studs are to be replaced ever so often. When exactly depends on how much track time and how hard you are capable of pushing the car. There is a big difference between a beginner/intermediate driver and a guy that can bring the car to with in an inch of its life. Every 1-2 years should be fine for most but once a year for those that push the car.
For perspective: This car has seen one 45 min race, practice, quali, Three time trial days and the equivalent of 20-25 track days this year. Personally I feel most comfortable buying studs from either Bimmerworld or Turner.....they race the products they sell. |
