10-02-2013, 10:05 PM | #1 |
338
Rep 923
idle drops and cold start revs fluctuating
I just noticed this at the beginning of this week, my cold start revs fluctuate as it will bounce up and down in a slow manner and once fully warm up the idle will drop to 500 rpm. When i press on the clutch it will go back up to normal. The car is approaching 62k and the only recent thing i did to it was changed the battery and coded it. Any advice on narrowing down on whats causing it will be greatly appreciated before i hand the keys to my only car to my indie shop and have them spend a couple days diagnosing it.
10-02-2013, 10:09 PM | #2 | |
121
Rep 175
10-03-2013, 07:59 AM | #4 | ||
337
Rep 1,489
10-03-2013, 09:15 AM | #5 |
338
Rep 923
10-03-2013, 09:52 AM | #6 | |
Bad Lieutenant
233
Rep 3,517
My car was like this: Techron concentrate plus took care of it, it never returned.
02 E39M5 | TiAg/Schwartz | Tubi Rumore | Ultimate Ti Pedals | E60 SSK | Jim Blanton 3.45 40/100% | Coby Alcantara | StrongStrut STB
10-03-2013, 11:00 AM | #7 |
163
Rep 1,506
Drives: '15 FO M4
Anyone know how much the ICV replacement job usually costs? Not for my car.
Fire Orange F82 Built by Alekshop | Pure Stage 2 Turbos | Akrapovic Evolution and Downpipes | ESS T-500 Performance ECU Software | Evolution Racewerks Chargepipes | Gruppe M CAI | Awron Gauge w/ Valve Control | KW Clubsport | Brembo GT 380 F&R | 19" BBS FI-R | BMW Performance Seats, Aero, and Steering Wheel | Vorsteiner Diffuser | IND Cosmetics
10-03-2013, 01:09 PM | #8 | |
145
Rep 1,130
10-03-2013, 01:13 PM | #9 |
338
Rep 923
[QUOTE=thekurgan
Techron concentrate plus took care of it, it never returned.[/QUOTE] Thanks ill look look into it, though my idle fluctuations are not as erratic as yours. Question, is that from a cold start? Mine doesnt hang around 1100 for long and settles down to 800 quickly in a normal bases. 2nd owner for this car, so i wished i knew how things came from the factory. |
10-03-2013, 02:15 PM | #10 | |
Bad Lieutenant
233
Rep 3,517
10-03-2013, 02:16 PM | #11 |
Bad Lieutenant
233
Rep 3,517
This actually makes a lot of sense, especially sitting overnight.
10-03-2013, 03:29 PM | #12 |
338
Rep 923
Well i just started the car and "check engine" light flashed for a moment until the dsc light came on. I had the multiple lights and dsc error light with the "reduced power" earlier this year and it stopped and therefore i didnt bother with it. Could these symptoms be a bad icv, bad throttle actuators, or simply bad spark plugs.
10-04-2013, 07:44 AM | #13 |
337
Rep 1,489
You can take it pep boys for a free scan to get the codes. Mine did the same until I replace the low pressure fuel rail sensor.
10-04-2013, 10:45 AM | #14 |
338
Rep 923
I got that replaced a little under a year ago, when it started to reduce power and pull multiple codes around spring time i first thought it was the throttle actuators but it all of sudden it stopped and went away. Im thinking it could be the icv now that the idle is acting up. The transmission is whirring a little more louder and i dont get it only idles normal only when the clutch is pressed.
10-04-2013, 02:56 PM | #15 | |
337
Rep 1,489
For what it's worth, I am at 80K and only changed the low pressure fuel rail sensor. |
01-23-2014, 02:14 PM | #16 |
48
Rep 194
Drives: 2024 X3 M40i, AW
