09-24-2013, 11:18 PM | #1 |
283
Rep 1,017
Pads ... Not the libra kind
Hi all,
Anyone know where I can get a set of track pads for the 1M (M3 shape, size) before the weekend? I'm looking for the Ferodo DS1.11 but open to other comparable options (endless ME20, etc). Don't want street/track pads, looking for something I swap out for track days only. Cheers Ian |
09-25-2013, 12:39 AM | #7 |
13
Rep 187
try vsport.com.au
2006 E87 130i
M3 front and rear arms, M3 Front and rear ARB , Quaife LSD, BMW performance wheel (non electronic), 135i Brakes, DS2500 pads, Apex wheel studs, Adjustable Bilsteins, API Half cage, Hankook Z221's (track) and Bridgestone RE002's (street) 225's all around |
09-25-2013, 02:10 AM | #8 | |
18
Rep 442
I have five sets of pads, and they are generally purchased as E92M3 equipment (equivalent to 1M), although one set was handed down from an E90M3 racer. |
09-25-2013, 03:20 AM | #9 |
18
Rep 442
Okay, thanks Ian (Syd). I think our brake issues are behind us, through trial and error (avoid OEM if at all possible).
Ian (Melb), I hope you find prompt resolution because there is one particular 1M hunter who will show our brothers no mercy on circuit. |
09-25-2013, 04:23 AM | #10 |
283
Rep 1,017
Thanks for all the replies.
So far no luck getting a set of DS1.11, 3 weeks away apparently. I'm away next week so I think I've just left it all too late. Might have to do Phillip Island with oem setup. |
09-25-2013, 05:43 AM | #11 | ||
127
Rep 3,099
For the track, http://www.1addicts.com/forums/showthread.php?t=559124 People seem to haven't had an issue just putting on m3 pads front and rear, given calipers, rotors.. Entire rear axle.. are identical, they'll fit. What's with the sensor not fitting though? Via ecstuning, realoem and bmminiparts, ALL e9x and e8x share the same wear sensors.. Sounds like an issue with those pads, rather than being m3 or 1m pads |
09-25-2013, 09:04 PM | #12 | |
17
Rep 444
Your other option is to use the pagid yellow for this round ? Oem setup on PI should be fine if you only push it hard for 2 laps max per session. In our last piarc run I brake earlier like how I would drive on the street and it went thru all 5 laps per session ok. 3rd hot lap i started to feel the slight spongy feeling |
