09-18-2013, 12:44 AM | #1 |
Supreme Allied Commander
3881
Rep 54,455
Drives: F80 M3
New product: Rogue Engineering Front Tension Rod/Arm Upgraded Bushing
Get in Control!
Are you looking for more control over the front end of your E82 1M/E9X M3/1 and 3-series with retrofitted M3 arms? We've got the solution for you! While the stock front tension arm bushings are designed to offer a compliant ride while trying to control the front, it cannot overcome age, added power, or increase use (like at the track). This front bushing takes a large share of the suspension load under braking and hard cornering. Our solution is designed to to outlast and outperform the factory bushing in many ways. Rogue Engineering's Tension Arm Bushings (TABs) is an elegant, engineered solution to this issue. Rogue Engineering's TABs are designed allow the thrust arm to move without this spring load, but instead, allowing movement though its range without this specific resistance. By allowing the center bolt sleeve to pivot instead of our custom urethane-silicone bushings smoothly, there is no unnecessary wear and tear. Our exclusive, made in USA, urethane bushing has all the same properties as the other bushings Rogue Engineering produces. A special silicone formula is injected into each and every bushing mold during the casting process to ensure a lubricious film impregnated at all times (even without grease!). Another Urethane Bushing? Some will try to compare the Rogue Engineering Thrust Arm Bushings to a currently available urethane replacements. There is a big difference! Instead of using urethane to control the entire area of deflection, we've engineered an aluminum housing to reduce the ID of the hole of the thrust arm bushing. By doing this, we can fine tune the urethane compound so that we can get performance without unwanted NVH. In order to get our level of deflection control, other companies would have to make their entire bushing so incredibly hard that their product would either vibrate, squeak or both! Less unwanted bushing deflection means more control! Take control of your BMW! These bushings are available in our STREET compound (black) or TRACK compound (blue). This product fits the following vehicles: E9X M3, including Coupe, Sedan and Convertible E9X 3-series with E9X M3 front tension arm retrofitted E82 1 M Coupe E8x 1-series with E9x M3 tension arm retrofitted More details here: http://www.1addicts.com/forums/showthread.php?t=888312 Last edited by HP Autosport; 09-19-2013 at 01:47 PM.. |
