08-31-2013, 12:44 PM | #1 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Updated (Improved) Water/Meth Results on ESS VT2 650
I posted my results of my Snow Performance water/meth install and initial dynos in these two links below -
Install: http://www.m3post.com/forums/showthread.php?t=868939 Initial dynos: http://www.m3post.com/forums/showthread.php?t=875549 I was scratching my head for a while as the dyno results were initially so poor. The car FELT just as fast, if not faster on the road, but the results from the water/meth dyno's were showing massive power declines compared with the dynos from the car pre- water/meth. I'm not tuned for water/meth (running Boost Juice), but just turning it on was beneficial for the few ESS VT2 S/C owners. Plus for me, given that the car sees the track, I wanted it more so for just keeping IATs in check which helps other things like oil temps. I don't have CAN-integration so I couldn't see 100% of the variables as to why the car was doing what it was doing on the dyno. Not wanting to give up just yet, I thought that the car might just not like immediate changes - since during my dyno runs, we were experimenting real time with different nozzle sizes and the results were just getting weirder and weirder. I rationalized that I could isolate the variable of "changing things" (that is, changing from turning meth on or off or changing out nozzle sizes) simply by resetting adaptations between any change that I do. So I went back to the dyno with the laptop and something interesting happened...power almost restored to normal. In fact the results on the first run (red line RunFile 63 with meth off) looks very similar to my highest HP run prior to the water/meth install (blue line RunFile 37). The difference between runs 37 and 63 can be explained because of the higher IATs, as it was a much hotter day comparatively, so the results make sense. Then I reset adaptations again and turned meth on for RunFiles 64 and 65. While power is down a little, it's not down by much at all - and best yet, the numbers are consistent. I included IAT data in my dyno's below, which show IAT drop on the water/meth runs (RunFiles 64 and 65) as compared to when meth was off for the first run (RunFile 63). While I didn't make any more power, it's nice to know that I didn't lose any power. While I'm down ~ 20 RWHP from when I started this ordeal, I'm ok with that because of the added protection I'm getting from the octane and cooling effects of the water. While dyno numbers are one thing, it's only a guage and the real test will occur in early October at the Shift S3ctor Coalinga Airstrip Attack. It will be interesting if I could run another S/C M3 that makes the same or more HP on the dyno - to see if the dyno is telling me everything. I have a feeling that it isn't. I have another upcoming dyno in a couple weeks (9/21/13) where I'm going to do something interesting - pour some 40 degree water/meth into the reservoir - and see what happens. Stay tuned
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
08-31-2013, 12:50 PM | #2 |
34
Rep 454
Drives: :O
60-130 time will tell you everything about the value of having this.
How does the car feel up top compared to before? Looking forward to shift sector results. Good luck. |
08-31-2013, 02:39 PM | #4 |
BimmerPost Supporting Vendor
731
Rep 3,735
This is one of those odd times where the dyno cannot correctly interpret how the car actually performs. Without a doubt the car is faster and more consistent after repeated pulls on the actual tarmac and at speed.
BMW PERFORMANCE SPECIALISTS. Race Engines. Suspension. F/I. Brakes. Race Preparation. Factory Service. Alignments.
OFFICIAL PARTNERS: KW. MOTON. Brembo. AP Racing. BBS Motorsport. iND. HRE. Turner Motorsport. VAC. BMW Motorsport. Facebook | Instagram | Yelp! | Flikr Phone: 949-233-0448 | E-Mail: info@mrfengineering.com |
09-01-2013, 09:07 AM | #5 | ||
3431
Rep 6,771
Drives: 2016 BMW i8
Thx Mark...I'll vid all the Shift S3ctor runs. I'm going to try to run cars with 100+ more HP just to see what happens. The M3's with DCT usually do pretty well against high HP cars with a manual trans. Quote:
There's one thing for sure - the reliability has been perfect - unlike my 335 water/meth system which was so inconsistent/frustrating. You did a stellar job with this. Thanks again.
09-01-2013, 03:53 PM | #6 | |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
Glad to see your still enjoying the car! Hope 2 see you on the 29th!
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
09-02-2013, 06:02 PM | #7 |
191
Rep 1,317
My brother is running a Stage 2 AA kit on his E46 M and he told me that he adds 10 oz OF 100% methanol to the boost juice mix and his car seems to be running much better.
09-02-2013, 07:57 PM | #8 |
123
Rep 951
Longboarder, you made a comment how you are down 20hp from when you started. I'm not sure I follow because your meth off dyno (run 63), while down 20 from your best run a few weeks ago (run 37) was due to temperature conditions, not the meth. Am I correct?
09-03-2013, 03:52 PM | #9 | |
3431
Rep 6,771
Drives: 2016 BMW i8
09-03-2013, 09:57 PM | #10 |
123
Rep 951
Got ya, yeah I see that the meth brought the IATs down to where run 63 (original no meth) was which one would think would at least give you run 63's performance. Have you tried less meth, more water? Say 60/40 and 70/30?
09-03-2013, 10:10 PM | #11 |
8215
Rep 18,823
Drives: BMW
Looking forward to seeing this in action @ Shift Sector.
09-03-2013, 10:44 PM | #12 |
501
Rep 4,033
Me too, so far he's done very well.
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
09-08-2013, 06:50 PM | #14 |
140
Rep 1,665
Could you sell me a set up as a kit? I've got a ess 650 kit
09-08-2013, 08:54 PM | #15 |
9
Rep 206
