M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      08-30-2013, 04:56 AM   #1
M5 TT
Scotland
169
Drives: F90 M5
19" wheel / tyre issue
I specked my car with 19's for a few reasons. I like the M5 look and I hate road noise, lastly the 2.5k premium for the 20's was not worth it.
Anyway,
Got a HUGE tank slapper on last night while passing a few cars on a "A" road.
Nailed it, pulled out hit the white lines then the car started to swing from side to side ( wheels were not spinning), backed off a bit it steadied out, nailed it again then moved back to my side of the road and again crossing the white lines the car was just about uncontrollable.
Thinking this was a once off for some reason I found a quiet bit of road and tried it again, although still did it, it was miles better but the white lines were not so pronounced. Looks like the tyres struggle with new high, thick white lines.
I wonder if the higher tyres wall of the 19s are flexing under full throttle then when hitting white lines exaggerates the issue??
Not sure but not how a 70k car should perform.
My rear tyres are at 2.2 bar. Will up this a bit maybe they are just a fraction low?
I did read on here someone complained about his car feeling sloppy at the rear and was blaming his spacers ( I don't have spacers) wonder if its the same issue. Anyone else suffered from this ??
540i
GTR-R35, F90 M5, X3MC, RS3, RS7, M5, S7, S3, RS3, RS6, GTR R35, 996 Turbo, M5, RS6 V10, Cayenne Turbo S
      08-30-2013, 06:13 AM   #2
JOHNBMWM5
Live for today tomorrow never comes
JOHNBMWM5's Avatar
United Kingdom
1989
Drives: 2022 LCI Marina Bay Blue/ Smok
Anyway,
I set mine to 36 PSI all round, pick it up Sunday.
If I load it up 36 front 38 rear fully loaded 36 front 40 rear.. Try it.
PS) i'm on 20" wheels.
Live for now, life is too short.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather
      08-30-2013, 06:51 AM   #3
Netwon
Netwon's Avatar
8
Drives: '12 BMW M5 Alpine White
2012 BMW M5  [0.00]
M5 TT I just took a quick check of Scotland weather (Glasgow) once you get below 15 deg C you need to start being careful when you walk on it from my personal experience. 7 deg C the stock Michelin PSS tyres are useless. I can break the back end loose at 100km/h easily and have to take care when changing lanes when it is < 15 deg C (worse if damp). Pull out to pass then apply power or things can get squirmy!
2.2 bar is a little light. A hair over 2.5 bar works good for me (36PSI)
Netwon
      08-30-2013, 06:53 AM   #4
M5 TT
Scotland
169
Drives: F90 M5
That's a big difference over mine. You are running 2.5 bar
My current pressures,
One rear tyre is at 2.2 bar. 31.9psi. Other rear is 2.3 bar. 33.3 psi
540i
      08-30-2013, 07:13 AM   #5
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
I believe Newton has it right. I picked my car up in December and the daytime temps were low 40s to high 30s F, and the rear tires would slide with minimal throttle input, even without white lines. When it's warm they're great, but very slippery in the cold. I use 36 psi front and rear for the street. Oh, and I have the 19s also.
      08-30-2013, 08:10 AM   #6
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
Winter tyres are the way to go, I have 20" wheels and Michelin PS4 alpines.
They are very sticky.
      08-30-2013, 09:27 AM   #7
Danmar
Drives: 2013 M5 blk/blk
I have noticed a similar but less pronounced problem. When I pull out to pass I often feel a lack of control when going over the centre line, a little disconcerting. Not a temperature issue. I have 20's. Maybe I should check the tire pressure.
      08-30-2013, 09:35 AM   #8
eddiedent
Drives: 2013 BMW M5
FYI ,20" tire option is only $1300.00 MSRP.
      08-30-2013, 09:41 AM   #9
M5 TT
Scotland
169
Drives: F90 M5
Yeah where u live maybe. UK is £2500 extra
540i
      08-30-2013, 10:29 AM   #10
Netwon
Netwon's Avatar
8
2012 BMW M5  [0.00]
Unless it is a really hot day (35C+) and the road is dry of you walk on it while changing lanes you'll feel the center line. I guess that what 500 ft-lbs @ 1500 rpm gets you!
      08-30-2013, 10:40 AM   #11
M5 TT
Scotland
169
Drives: F90 M5
35c haha it's the uk that is never going to happen. You said Glasgow was 15c today that's our summer
My 535d had around 780nm around 570lbs ( crazy fast diesel) and never did anything like this.
I don't mind feeling the lane change but this was pretty extreme. Will try more pressure tonight and see how it goes.
540i
      08-30-2013, 11:24 AM   #12
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
I paid £2450 for these 20" wheels and Michelin PS4 Alpines.
      08-30-2013, 11:42 AM   #13
M5 TT
Scotland
169
Drives: F90 M5
I am looking for 20s at the moment and was going to use my 19s for winter tyres.
Struggling to find a 20" wheels that are a bit different to the norm.
540i
      08-30-2013, 03:14 PM   #14
M5 TT
Scotland
169
Drives: F90 M5
Increased pressure to 36psi. It is better. I would describe it as squirmy now. It was down right dodgy at 32psi. Still not good though
540i
      09-16-2013, 04:39 PM   #15
M5 TT
Scotland
169
Drives: F90 M5
The more I play the more I think it's the rear springs that are too soft. Wonder if the issue goes away with H&R spring or similar?
540i
      09-17-2013, 03:08 AM   #16
JOHNBMWM5
JOHNBMWM5's Avatar
United Kingdom
1989
You say that but some who have tested the car leave the suspension settings at "Comfort" to aid in putting the power down
What setting are you driving hard on?.
      09-17-2013, 03:28 AM   #17
M5 TT
Scotland
169
Drives: F90 M5
I have tried all 3. The hardest setting reduces the squirm but that only makes the shocks harder and does nothing too the springs.
I think you are right. Soft setting in straight line will allow more transfer weight to the rear wheels but it seems when you add steering input it starts to move around.
I wonder in the fight to make this car comfortable ( which it is) they have gone for a slightly softer spring and upped the ARB diameter to stop body roll making it a bit sloppy under certain circumstances. i.e crossing the centre line on "A" roads. Never happens on the dual carriageway.
I guess it's because I nail it combined with quick steering input and crossings the centre line is enough to unsettle the car.
540i
