08-29-2013, 12:16 PM | #1 |
Latvian Gangstah
84
Rep 570
DCT Vibration in certain gear at certain rpm during decel?
2010 E90 M3 M-DCT
I've noticed something odd happening to my car. When I decelerate, downshift to 4th and let the car engine brake from ~4300 rpm to ~3900prm range, sometimes I get vibration/noise from what I think is transmission that resembles tire noise/vibration as if you were going over rippled pavement. It seems to be doing it only in 4th gear, only in that rpm range and only during engine braking. It's definitely not subtle/faint, but not crazy/grinding either. It happened maybe 3 or 4 times during last 4 month. But this week it happened twice. Makes me a little worried. I feel it's definitely coming from the driveline though, not suspension/tires. I hate to go to the dealer with "my car is making this weird noise/vibration" type question, and not being able to reproduce it consistently. Hence asking here first. Any thoughts? Thank you.
2009 E92 M3 Melbourne Red 6MT
[SOLD] 2015 YMB BMW M3 M-DCT [SOLD] 2010 Alpine White E90 M3 M-DCT [SOLD] 2002 TiAg E46 M3 manual Last edited by jbraslins; 08-29-2013 at 12:23 PM.. |
08-30-2013, 09:47 AM | #2 |
Latvian Gangstah
84
Rep 570
Anyone? Bueller?
[SOLD] 2015 YMB BMW M3 M-DCT [SOLD] 2010 Alpine White E90 M3 M-DCT [SOLD] 2002 TiAg E46 M3 manual |
10-08-2013, 12:12 PM | #3 |
Rep 23
I have a similar noise, that I could not duplicate when I took it to dealer. I hear mine when decelerating\engine braking in any gear. The noise disappeared when I took it into dealer. That was last month while it was still under warranty. Now a month later the noise has returned, but out-of-warranty!
I had a tech ride with me, It sounded like to me it was coming from the rear diff, drive shaft area. When they couldn't duplicate the problem he told me sometimes the AC fan (squirrel cage) in blower is known for getting out-of-alignment and it can cause a noise to come out of the rear AC vents near the back seat, which is where I heard the noise. I'm not sure if this is my problem, but it looks like another trip back to the dealer is in order, now what do I do if its a transmission problem discovered under warranty and now its out of warranty? |
12-06-2013, 01:38 AM | #4 |
Rep 7
op +1, mine start to make similar noise when deceleration, it happens in higher gear mostly 5th at lower rpm ( 1500-2500). The noise sounds similar when you driver over rippled pavement, low pitched rumble. When I shift to neutral the noises goes away, so must be the gearbox that is having issue. Mine's E92 2010, DCT.
01-22-2014, 11:52 AM | #5 | |
12
Rep 175
D mode. I use D mode only when in stop and go traffic, so i notice it more in the lower gears. In S, it goes away. Low pitch rumble is exactly the right description, like a "whomp, whomp, whomp" sound. I took it to the dealer for inspection but they told me it was only tire noise. They wanted $ for more thorough inspection but I passed. I'm out of warranty. Anyone have a good diagnosis?
2009 E92 M3 / DCT / AW / Black Extended / Akrapovic Evolution / BPM Engine+DCT Tune / Dinan Stage I + Camber Plates / HRE C20 / Valentine One by Alekshop
01-22-2014, 03:33 PM | #6 |
Latvian Gangstah
84
Rep 570
Mine quit doing it. No idea what it was, but I am certain it was not tires.
01-23-2014, 12:20 PM | #7 |
12
Rep 175
Did you do anything that made it stop? Change fluids, tune, seals, etc?
02-05-2014, 01:10 PM | #8 |
Latvian Gangstah
84
Rep 570
Nope, just went away.
