BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
      08-27-2013, 08:03 PM   #1
Raydogg920
7
Drives: E92 M3
Bank 2 side???
About to replace a bad pre cat O2 sensor, the SES code is calling out bank 2.
Looking to confirm that is the drivers side?
P2629
O2 Sensor Pumping Current Trim Circuit/Open Bank 2 Sensor 1
Fault: Bank 2 pre-catalyst oxygen sensor pumping current calibration error
      08-27-2013, 09:55 PM   #2
Mmmdreamer
Mmmdreamer's Avatar
Drives: 08 e90 M3 Jet Black
yo yo. Bank 2 = Driver Side.
http://blog.bavauto.com/10109/bmw-en...-6-cyl-v8-v12/
I had the exact same code.
[08 e90 M3. Jet Black/Black. Dinan Rear Exhaust. ACM Test Pipes. ESS Tune. Eibach Pro-Kit + e36 bumpstops. 18x10 Apex Arc-8. AA Air Filter. RPI Scoops. CREE Angel Eyes. OEM Blacklines. Black Reflectors. Gloss Black Grills. Matte Black Gills. ZCP Shift Knob]
      08-27-2013, 09:58 PM   #3
JEllis
JEllis's Avatar
532
Drives: E36 M3, E92 M3
Have you done an O2 sensor change on the E92 M3? Just FYI, you will want to unplug the electric connection for the sensor prior to unscrewing it. It will just make things easier since you dont care about the bad sensor and it will also prevent you from damaging the bracket the sensor plug fits in. It will also get everything open for plugging in the new sensor after you have screwed it in. If memory serves, taking out the rear 4 bolts and center bolt of the skid plate will give you enough room to access the connection points for the front O2 sensors. Just dont want you to make some of the same mistakes I did.
Jason
http://www.m3post.com/forums/signaturepics/sigpic14547_7.gif
Instagram: jellismotorwerks
      08-28-2013, 05:26 AM   #4
Raydogg920
7
Drives: E92 M3
Nice, thx.
m3post
