08-25-2013, 10:09 PM | #1 |
24
Rep 368
Drives: E92 M3
Dinan Underdrive Pulley Kit
I’ve been thinking about purchasing the Dinan Underdrive Pulley Kit for it claims an additional +11 horsepower @ 8400 rpm and +7 lb-ft torque @ 8400 rpm.
For all who have the Dinan Underdrive Pulley Kit how do you like it? For all that are running another brand of Underdrive Pulley kit what are your thoughts on it compared to the Dinan? Do you feel it makes a difference? Thanks in advance,
2009 E92 M3 DCT: BPM tune + DCT tune & Servotronic | Velos Solo VII 19x 8.5, 19x11 | Michelin Pilot Super Sport 255/35/19 front 295/30/19 rear | M Performance Exhaust | BCM Air Intake Filter
08-25-2013, 10:20 PM | #2 |
21117
Rep 20,741
Drives: 2021 911 turbo
I have been running the Dinan pulley for the past year. So far I am reasonably happy. I believe the Dinan to be one of the more aggressive pulleys, i.e. It slows down the accessories more. The car seems slightly stronger in the top end. However it does seem to also run a bit hotter at the track.
08-25-2013, 10:32 PM | #3 |
24
Rep 368
Drives: E92 M3
Hmmm......is the reason for it running hotter due to the accessories being slowed down more?
08-25-2013, 10:42 PM | #4 |
Rep 67
I got the Dinan pulley installed at the same time as a tune. Hard to comment on just the pulley. I did notice my car running hotter in daily driving. No negative affects, just shows up 5-10 degrees on the temp gauge.
08-25-2013, 10:49 PM | #5 |
24
Rep 368
Drives: E92 M3
Interesting...... other than running a little hotter how do you like it overall?
08-25-2013, 11:48 PM | #6 |
coupe la goon
373
Rep 1,640
Drives: green, black, white
Garage List 2011 BMW 1M Coupe [10.00]
2013 BMW M3 Coupe [10.00] 2010 BMW 535i xDriv ... [0.00] 2008 BMW M3 Coupe ( ... [0.00] |
I recently installed the pulley on my 08 6MT. Not only was installation very straightforward, I was exceptionally surprised at how the RPM response has improved. Shifting during normal driving is lovely, the RPM fast quickly enough to just make things work. I'm also a huge fan of their machine work. No change in oil temperature that I have noted.
08-26-2013, 12:04 AM | #7 | |
Rep 67
We'd have similar mod's if you do the pulley. I've got a Challenge USA Xpipe and rear exhaust, AFE intake, the pulley, and an ESS tune. Last edited by AW M3; 08-26-2013 at 12:09 AM.. |
08-26-2013, 01:05 AM | #8 |
499
Rep 2,400
Have the Dinan pulley and really like it. As someone said, one of the most aggressive pulleys diameter wise out there, but I only notice maybe 3-5 degrees of oil running hotter in high rpm driving or on the track, if even that. With the pulley, cold starts and starting from 1st gear was smoother for some reason, engine overall seemed smoother at lower end. Power difference is only noticeable at the top end, but it's there (and dyno gains are proven for pulleys). Only downside is that you need special sized belts (that are also difficult to put on for DIYers), but I believe the belts are NAPA, so therefore probably readily available and Dinan also sells them.
08-26-2013, 02:40 AM | #9 |
569
Rep 3,742
Do any of you guys notice any issues with steering or A/C, etc.?
I've also been thinking about a Dinan pulley to go with my Dinan intake, Akra Evo, and BPM Stage II tune. While I'd like to get as close as possible to 400 whp, I don't want to sacrifice too much daily-driver reliability/practicality to do it. As an aside, I've always found it surprising that the Dinan is the most aggressive pulley since they tend to be on the conservative side of things (which I actually appreciate). Wonder what their rationale is with their choice in pulley diameter . . . |
08-26-2013, 07:45 AM | #10 |
24
Rep 368
Drives: E92 M3
Thanks to all for the input, I will be ordering the pulley along with the two replacement belts today!
08-26-2013, 07:54 AM | #11 |
7494
Rep 12,310
I'm assuming it's because you are slowing down the water pump.
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
08-26-2013, 08:13 AM | #12 |
Grown Azz Man
429
Rep 3,021
I've been running it for about 2 years and there's no negative impact. Even on Hot Houston area track days I don't notice any temp increase. As someone stated, the power will be noticed on the top side....above 4k. And the smoothness in which it's delivered is worth the price of the pulley kit..............Phil
2016 GT4.....Sapphire Blue Metallic, Platinum stitch Leather/Alcantara interior, Carbon Fiber Trim, PCM w/Nav, Guards Red Belts, 2 Zone Climate, Sport Chrono, LWB, Smokers Pack, Big Gas Tank, Light Design Pack, Bi-Xenon w/PDL, Auto Dim Mirror, Clear Side Markers, GTS Clear Taillights
08-26-2013, 08:57 AM | #14 | |
24
Rep 368
Drives: E92 M3
08-26-2013, 08:59 AM | #15 |
24
Rep 368
Drives: E92 M3
That would make sense!
08-26-2013, 09:06 AM | #16 | |
24
Rep 368
Drives: E92 M3
It’s $399 on Dinan's website, however even if rounded up to $500 that's still a great deal for a proven additional +11 horsepower @ 8400 rpm and +7 lb-ft torque @ 8400 rpm. There's no other mod for $500 bucks that will get you those hp & torque numbers all without interfering with your warranty!
08-26-2013, 09:29 AM | #18 | |
24
Rep 368
Drives: E92 M3
08-26-2013, 09:36 AM | #19 |
24
Rep 368
Drives: E92 M3
I shot Gilbert over at McKenna Performance a PM hoping he can get me a better price on it, waiting for him to get back to me. Sometimes McKenna Performance will have discounts on Dinan products.
08-26-2013, 09:45 AM | #20 |
131
Rep 2,408
08-26-2013, 10:19 AM | #21 |
24
Rep 368
Drives: E92 M3
08-26-2013, 01:38 PM | #22 |
569
Rep 3,742
Me too, please!
Regarding the water pump, I wonder if a tune could slightly increase the speed of the water pump to the point where, with a pulley, you'd basically be breaking even or maybe slightly less than the water pump on a stock car. In that way, you'd be focusing the under-driving on all the truly non-essential accessors (A/C, steering, etc.). So, basically, just a slightly tweaked tune file for those with pulleys. |
