      08-23-2013, 01:42 PM   #1
BadOneThreeFive
BadOneThreeFive's Avatar
Guam
60
Drives: 2008 BMW 135i
Help resetting window limits.
Before I begin, yes I have searched and tried almost every possible procedure there is for resetting the window limits and nothing has worked for me.
I have an 08 135i coupe that I just replaced the passenger window regulator on. I did not replace the motor. After install, the window works fine but will only go up maybe 95% of the way when the door is closed and drops down to let say 90% when I open the door.
I have found so many different procedures online for fixing this and nothing works. Can somebody please give me a definite fix to my problem? Thanks
08 135i N54
- Vargas Stage 1 Turbos with Billet wheels
- BMS Intake, BMS Charge pipe, AR DPs, Stock mids, berk race muffler delete
- JB4 G5 Map 3 75 Meth Additive with RACE DME flash
- MS-109 and 100% meth injection (Single CM12 nozzle)
      08-25-2013, 09:32 AM   #2
BadOneThreeFive
Guam
60
Anyone?
08 135i N54
      08-26-2013, 04:32 PM   #3
dtwyim
dtwyim's Avatar
52
Drives: BMW no more
Did you try what is written in the manual? Failing that, may be dealer?
      08-26-2013, 05:01 PM   #4
BadOneThreeFive
Guam
60
I just tried multiple different procedures that I have seen online. Not sure if they are from the manual. Where can I find one?
08 135i N54
      08-26-2013, 09:51 PM   #5
BadOneThreeFive
Guam
60
Fixed it. It wasn't anything to do with the anti trap or the limits. I tightened down the window to low when I changed out the window regulator. If you loosen the 2 torx screws holding the window onto the brackets you can move the window up and down slightly. All I did was move it up and tightened it. Problem solved.
08 135i N54
