      08-12-2013, 12:41 PM   #1
Burak
Burak's Avatar
Turkey
Drives: E87 120d
2005 BMW 120d  [0.00]
Exclamation Changing Boge Sport with Koni Sport Shocks
My car has M sport suspension from the factory but recently I changed the M springs with Eibach Pro-Kit springs which made the ride a little more stiffer and dropped the front - 10mm over M springs, the rear height stood the same.
I'm still not happy with the setup as the car is not as stiff as I want. I don't want the body to roll that much in the turns or while it's drifting. So I decided to change the Boge Automatic Sport shocks with stiffer ones.
Bilstein B6/B8 was my first choice but unfortunately it's not sold in my country (no distributor), so I have to choose Koni Sports (Yellow) which are also adjustable in the fronts.
Do you have any experience with Yellow Koni's + Eibach Pro-Kit's on 1 series? Will this setup serve my needs? I'd like to have your comments as I'm going to buy the shocks in a couple of days.
I guess as I have sport suspension option from the factory, my sway bars are different than the 120d's with standard suspension, but I'm not %100 sure. Do you also recommend me to change the sway bars?
'05 E87 120d M Sport
      08-12-2013, 11:14 PM   #2
_Ryan_
59
Drives: E87 130i
2005 BMW 130i  [5.24]
nh-tuning.de will ship you B8 which are the 'matched' shock for your springs.
oh, and H&R swaybars or similar would be another option to reduce body roll. With the softish rate of the Eibach springs/B8's I would personally upgrade swaybars. I have used a near identical setup on another car with great success.
There are two schools of thought:
1- Use Shock/Spring to control roll through stiffer rates, use swaybars to set 'balance'
2- Use swaybars to reduce body roll, use softer(relative to point 1) shock/spring to improve traction, grip, braking etc.
I've run Bilsteins and Konis, i don't buy Koni any more.
      08-13-2013, 02:00 AM   #3
Burak
Burak's Avatar
Turkey
Drives: E87 120d
Thanks for your valuable advises. I tried to purchase B8's from nh-tuning.de and learned at the checkout that they don't ship to Turkey
I guess I'll have to go with the yellow KONI's
      08-13-2013, 02:39 AM   #4
_Ryan_
59
Drives: E87 130i
Contact them via email or use eBay. I had to use email for my PSS.
Details are below:
NH Tuning
Jens Krause
E-mail : info@nh-tuning.de
Internet : www.nh-tuning.de
Ebay : http://stores.ebay.de/NH-TUNING
      08-14-2013, 05:36 AM   #5
Burak
Burak's Avatar
Turkey
Drives: E87 120d
Details are below:
NH Tuning
Jens Krause
Thanks for you recommendations.
I've found the official seller of Bilstein in my country and ordered the B8 shocks. I'll have them within 15 days
Tags
120d, e87, koni shocks
