XBimmers.com | BMW X6 Forum X5 Forum
TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X6 Forums > General BMW X6 and X6M Forum
      08-09-2013, 04:24 PM   #1
titanle
titanle's Avatar
50
Drives: 2010 X6 Activehybrid
Question rubbing or bottoming out after lowering?
Im just curious as to whether anybody has had problems with their X6 rubbing or bottom out at all after installing lowering springs?
      08-09-2013, 05:12 PM   #2
Jess///M
10
Drives: 2016 X6M
I have the Dinan drop and have never experienced that issue. It is, afterall, only a .75" drop, but the look is still agressive with excellent performance. If you're at all concerned about bottoming out, I would go for a conservative drop, which will also preserve the quality of the ride.
      08-09-2013, 10:47 PM   #3
titanle
titanle's Avatar
50
Thats exactly why i chose the H&R 1.2/1" drop. I want a minimal drop for my X6 but from what ive read it seems like in actuality the drop ends up being much more than 1.2"/1"......
      08-10-2013, 03:14 PM   #4
Boosteeddc
Drives: 2010 x6m
Mine did when I first lowered it. Had the rear lowering link with the h&r springs. Rear was tucked! Then drove like a low rider with no shocks. So I lifted it back up quite a bit. The front isn't adjustable though but the rear kinda brings it down with it
      08-11-2013, 06:00 PM   #5
titanle
titanle's Avatar
50
so you only had rubbing issues in the rear since it was dropped real low right? Did the front rub at all? considering we have links in the back I'd only drop it .5-.75" very minimal.
      08-11-2013, 11:38 PM   #6
Boosteeddc
Drives: 2010 x6m
Yea. My car is fairly low right now with 22" setup. No rubbing. But as you know. These springs are very bouncy. But that's about it
      08-12-2013, 02:53 AM   #7
titanle
titanle's Avatar
50
I think im gonna bite the bullet and just get them installed, we'll see how it goes. Theres a lot of gap in the front so the 1.2 should be fine. In the rear since its links I can play with the drop.
      08-15-2013, 02:39 PM   #8
zerrantoss
25
Drives: 2011 X6
I had mine dropped with H&R. Never had problems.
In fact, it's still got more clearance than normal sedans do.
      08-15-2013, 09:48 PM   #9
Boosteeddc
Drives: 2010 x6m
It really does. I highly doubt anyone will actually run into rubbing issues with these unless you lower it to the lowest setting. And in that setting, I don't think the car is still drivable
      08-16-2013, 01:29 AM   #10
titanle
titanle's Avatar
50
So i got it lowered today, turned out pretty nice I must say. I got about a 2" gap all aroun now. Initially the back was almost tucked so I had them raise it back up somewhat. I'll post some pics tomorrow of the end result. The ride doesnt seem much different from stock. I drove about 20 minutes on the highway at a pretty high rate of speed and it felt the same as stock.
      08-16-2013, 12:51 PM   #11
zerrantoss
25
Drives: 2011 X6
Congratulations!
The car looks more aggressive now, right?
It really looks a lot better after lowered, especially from the back.
Give it a few more weeks to settle.
      08-16-2013, 03:26 PM   #12
titanle
titanle's Avatar
50
Originally Posted by zerrantoss View Post
Congratulations!
It looks really mean!!! So far so good, spacers should be here monday and then we'll see just how good it looks. I'll make a thread in the pictures section.
xbimmers
