      07-18-2013, 11:42 AM   #1
HP Autosport
Supreme Allied Commander
Drives: F80 M3
Thumbs up Swift Spec-R Sport Springs for your E82 135i
Swift made Sport Springs Spec-R is made for true track racing enthusiasts that wants to take their vehicle to the next level.
Sport Springs Spec-R is engineered with 2 main characteristics.
1 Redesign lowering ride height to maximize the suspension performance allowing the vehicle to fully absorb road condition for maximum traction.
2 Increase in spring rate to further enhance cornering speed through entry & exit. The increase in spring rate is based on the vehicle factory stock valving settings. Sport Springs Spec-R is increase to the optimal rate that the stock shocks can handle. Higher performance shocks are not required, but recommended.
Spec R springs are wound with the same engineering as our sports springs. With the exception of stiffer rates and slight change in ride height; you can expect the same characteristics as our sports springs.
H5S.TW
Motorsport's most advanced spring material
Swift made a name for itself on the tracks of Asia, Europe, and U.S. by defying all accepted concepts and speculations about the future, if any, in coil spring science.
When many other company were looking at expensive and brittle titanium composites to create the next evolution of springs, Swift was looking at reinventing the entire science of coil spring dynamics. Swift saw that most others are using the old regular silicone chrome material, which was not strong enough. It used a heat tempering method that damaged the strength of the material that requiring more coils, in turn, more weight.
The material was also suffering from a short life span. With springs like this leading the industries, Swift saw room for improvement.
Swift's R & D team created material, called H5S.TW, which is stronger then regular silicone chrome material. Because of this material, we could make the spring wire thinner, and could wind the springs with fewer coils, which greatly decreased weight while dramatically increasing available stroke.
135i lowering:
1" in the front and 1" in the rear (from non-sport).
Spring rate:
-3.6kg/mm or 201 lb/in in the front
-9kg/mm or 503 lb/in the rear
Independent review here:
http://www.1addicts.com/forums/showthread.php?t=873692
NLA
      08-15-2013, 01:56 PM   #2
HP Autosport
Drives: F80 M3
Swift Spec-R reviewed here:
      12-19-2013, 07:25 AM   #3
dcaron9999
dcaron9999's Avatar
157
Drives: 2011 135i M package
Hi Harold.
Seriously thinking about pairing the Swift R spec springs with Koni Sports (inc adjustable rear shock option). Would they fit my Ground Control "Street" Camber plates or do I need new ones?
I track my 2011 135i M sport often from April to October, and use it as a week-end driver. Roads are not in very good shape here in Quebec, Canada with our nasty winters. With my bad back, Im hoping this combination wont make the ride too harsh, especially if I can quickly/easily dial the front+rear dampers from "firmer" to "softer" position.
How wide can my tires be with these springs, struts, and shocks?
Thanks.
2011 X3 35i with M pack + 2011 135i w/6SPMT | 255 square tire setup | Quaife 3.46 LSD | Diff lock down bracket | Bilstein B8+Swift SpecR springs+H&R FSB | CDV delete | BMS Oil Tstat bypass | ER FMIC & CP | N54Tuning DP | GC Street Camber Plates | M3 FCA +guide rods+RSFB's+Tranny mounts | Manzo toe arms | Cobb Stg2 agressive tune | Hawk DTC70 brake pads | RB SS brake pistons | Goodridge SS brake lines | Custom brake cooling ducts
      12-20-2013, 11:54 AM   #4
HP Autosport
Drives: F80 M3
Originally Posted by dcaron9999 View Post
Hi Harold.
Thanks.
Replied via PM.
      12-20-2013, 12:43 PM   #5
dcaron9999
dcaron9999's Avatar
157
Thanks Harold. Posted back here so others can benefit from your expertise.
My street setup is stock style 261 rims (18x7.5" and 18x8.5", with 225/40 and 255/35 RE-11 rubber). No spacers + no rubbing, with or without GC camber plates.
Originally Posted by HP Autosport View Post
If your GC plates are for OE type springs, they will work on the Koni and Swift Spec-R combo. You are limited to 235-245 front tires with the stock fenders. Rears can be up to 265 without any issues.
For wheel/tire fitment and clearance, am I also good with LTW5 17x8.5 and 245/40R17 racing compound tires?
Struts and spring will not change the inside clearance any so you will only have to worry about the outside. I say you need a few degrees of camber to clear the 245's.
      01-22-2015, 01:29 PM   #6
HP Autosport
Drives: F80 M3
bump
      04-14-2015, 02:22 AM   #7
HP Autosport
Drives: F80 M3
bump
      04-16-2015, 04:56 AM   #8
sr2223
8
Drives: 135i
Hi Harold
How much would it cost to ship these springs and koni shocks to Australia?
      04-22-2015, 11:54 AM   #9
HP Autosport
Drives: F80 M3
bump
      04-22-2015, 11:57 AM   #10
HP Autosport
Drives: F80 M3
Originally Posted by sr2223 View Post
Hi Harold
Did I already quote you? If not, please PM.
      06-27-2015, 12:38 PM   #11
HP Autosport
Drives: F80 M3
bump
      07-23-2015, 03:26 PM   #12
HP Autosport
Drives: F80 M3
bump
      08-14-2015, 12:02 AM   #13
HP Autosport
Drives: F80 M3
bump
      09-07-2015, 08:57 PM   #14
HP Autosport
Drives: F80 M3
bump
      09-24-2015, 12:31 AM   #15
HP Autosport
Drives: F80 M3
bump
      11-05-2015, 06:17 PM   #16
HP Autosport
Drives: F80 M3
bump
      11-23-2015, 08:32 PM   #17
HP Autosport
Drives: F80 M3
bump
      01-09-2016, 04:21 PM   #18
HP Autosport
Drives: F80 M3
bump
      01-19-2016, 08:07 PM   #19
HP Autosport
Drives: F80 M3
bump
      01-29-2016, 08:19 PM   #20
HP Autosport
Drives: F80 M3
Bump
      02-05-2016, 12:01 PM   #21
HP Autosport
Drives: F80 M3
bump
      02-19-2016, 05:00 PM   #22
HP Autosport
Drives: F80 M3
Bump
