BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
BPM
      06-26-2013, 06:05 PM   #1
Maypo
Maypo's Avatar
10
Drives: IBM E92
Brake Warning Lights
My '08 has had brake system warnings on for a little while. According to the selection of symbols, it is apparently related to the 'hill start' feature. Occasionally, the lights are off, but come on as soon as I begin driving. The only operational effect is that stability control is off.
It seemed to occur shortly after changing the front dampers. And I noticed the bracket on the inside of the driver's side damper was rotated inboard (I didn't get it properly re-positioned against the housing), and the swaybar link was rubbing a little against the cable/wire housings that pass through the bracket. I have since repositioned the bracket and regained clearance, but the lights are still on.
Is it possible, one of the wires was fractured inside its housing?
A system check revealed no codes for brake system failures.
      06-27-2013, 12:11 PM   #2
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
What are you using to check for codes? If there are warnings on the dash then there will certainly be an issue logged somewhere.
      06-27-2013, 04:43 PM   #3
Maypo
Maypo's Avatar
10
Drives: IBM E92
I had the codes checked by a local business. I will have them run another test.
m3post
