06-19-2013, 02:34 PM | #1 |
103
Rep 677
Tire Sizing, KW V3, and spacer ?'s!
I have coils on the way... not just for stance or performance but both... I want the car to actually handle/ function better than it is/ does now, not just look better!
I am currently set up with 245 up front and 275 in rear. I did possibly want to go up to 265F and 285R. My questions are: -should I size up or stay the same? (What will be best for handling/ cornering??) car is stage 2 power wise... keep 245F275R? or size up to 265F285R -will I rub? with what I have now? or going larger in both front and rear -do I need spacers? with what I have now? or is going up in tire size enough?
Follow my car/ life via Instagram @rdauito
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 |
06-20-2013, 07:57 AM | #2 |
103
Rep 677
I think I will try 255F/285R and no spacers just like the Safety Car. I love that thing! Full spec list in video description!
06-20-2013, 09:51 AM | #3 |
116
Rep 3,070
Can be very good really.
Just one thing to watch out: both Moto GP 1M and its "muse" E92 M3 GTS have this set up (with Pirelli PZero Corsa System tires) with a possible factory-tune in their DSC set up, since there is no stagger left like the stock 1M/M3. Both fronts and rears will have 26" of rolling diameter unlike the stock 0.5" difference. I also want to believe that this is a non-issue but I can't say am 100% positive about that. Otherwise, it is the dream tire-wheel combo.
"The mark of a great car is one whose overall competence exceeds what you should expect from its individual components and the 1M does just that", Chris Harris.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. Last edited by ozinaldo; 06-21-2013 at 08:24 PM.. |
06-21-2013, 11:26 AM | #4 | |
103
Rep 677
06-21-2013, 12:03 PM | #5 | |
116
Rep 3,070
When you pass to M3 GTS size tires on stock wheels which are the same wheels of 1M, the overall tire diameters will be 26" front AND rear so no stagger of 0.5", no difference or very little difference in terms of revs per mile. I don't have enough evidence to assume that stock ECU and DSC are flexible and adaptive "enough" to make this a non-issue. If you search M3 forums you will see there are people who did this and others who want to make this if and when Michelin releases 285/30/19 size PSS. You will also notice comments backing or doubting this particular tire size. For the size of stock wheels and space in wheel wells, yes this got to be the dream (street) set-up. I hope it is clearer now.
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. Last edited by ozinaldo; 06-21-2013 at 02:34 PM.. |
06-21-2013, 12:46 PM | #6 | |
103
Rep 677
2011 E82 1M #215 of 740 http://www.1addicts.com/forums/showthread.php?t=877009 Last edited by bmw13; 06-21-2013 at 01:14 PM.. |
06-21-2013, 02:33 PM | #7 | |
116
Rep 3,070
You have the KW which adds to complexity of this decision, especially if you are decided to go lower. As usual, it is very much to do with where and how you drive your car (track/DD or mixed), if you need to consider good tire manners in rain and also if you want to stay with stock wheels or not. A good 18" wheel shall give you yet another range of tire options to choose from. Good luck
BMW 1M-SOLD-: TECH: Evolve Race+N55mids, Evolve IC, Michelin PSS, ER cp, aFe filter, CDVx, Vorshlag camber plates, BMS OCC EXTERIOR: trunk spoiler, blacklines, black grills, IND goodies INTERIOR: Alcantara steering wheel, steel pedals, custom mats, MPower e-brake. |
06-21-2013, 11:58 PM | #8 |
54
Rep 509
I just had 265/30's mounted on the stock front wheels, no rubbing so far, it is pretty close, I have about a 1.5cm drop with the KWv3's.
My track rear tires are 285/35/18 - no rubbing. |
