      06-14-2013, 02:01 PM   #1
filet.M2c
filet.M2c's Avatar
784
Drives: M2c / mach e
Engine Malfunction
So this morning I went to start up my 08 135 and upon start up I got the half enginer sign with "engine malfunction" on the iDrive. I've read through some engine malfunction threads and my issue seems to be different that others here. Right when I started the car it was idleing extremely low (300-500rpm) and then just stalled out. I restarted the car like some suggest and it remained. The car was undrivable, so I just had it towed to the dealership here in Phoenix. I installed jb4 and have been running map 1 on and off for about 1500 miles. Waiting for the call from BMW... hope I'm not out a load of money...
      06-14-2013, 03:14 PM   #2
cheshirecat79
cheshirecat79's Avatar
Drives: 370z & 135i
you're gonna be out a load of money if you didn't uninstall that jb4, or in the very least put it on map0 before bringing it in
if they can't get an ecu reading or if they see an over boost target condition they may look for it
best of luck
      06-15-2013, 03:15 PM   #3
josemh23
josemh23's Avatar
Puerto Rico
16
Drives: 135i
2011 135i  [0.00]
If you solve your issue let me know.today I pulled from 4th and the engine made a weird revv sound. The half yellow engine like went up.. Unistalled Cobb and run again and half engine like pop again. My car is stock except berk exhaust.. I'm not mechanics inclined!!!! Any toughs? The weird thing is I just installed Cobb last week haven't had time to abuse it
      06-15-2013, 10:24 PM   #4
yawn
57
Drives: M2 Competition
Codes may help. Check it out - may help with self diagnosing.
      06-16-2013, 09:05 AM   #5
MIAblu1
22
Drives: 08 Monaco Blue 135i
One thing I'd definitely suggest is getting a good local BMW coder to run diagnostic on your car as it'll be MUCH cheaper than BMW's $135 diagnostic just to tell you the issue PLUS parts and labor for the fix. Provided you're no longer under warranty like myself or don't have anything for them to tell you you're not covered(work to the car causing it to be an unwarranted job)
      02-20-2014, 03:42 PM   #6
Black135ibmw
Drives: Black 135i
I am also having many error codes, rough idle smells like it is running rich, having problems starting, it will not go above 3000rpm and no turbo spool at all.
i have just replaced the starter motor and now i am having these issues, can anyone point me in the rite direction as there seems to be no cables off or anything like that, is there a fuse that could be causing the issue?
Here is a video of it running with the lights:
Here is a video of it starting up:
Here is it trying to start:
Thanks
      02-21-2014, 01:54 PM   #7
cheshirecat79
Drives: 370z & 135i
Originally Posted by synergist View Post
I uninstalled the jb4 myself and read the codes before I did and got error code 2E97 Generator. After I uninstalled the jb4 the car won't start at all now
Check the DME wiring.
