BMW M3 Forum (E90 E92)
      06-08-2013, 02:03 AM   #1
maicol76
194
Drives: E92 M3
pads for Alcon Superkit
I'm considering to try Alcon Superkit, but have no idea about available pads(like PAGID29)
If there is someone who has information about this kit, plz let me know.
      06-08-2013, 02:46 AM   #2
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
Pagid RS29 is available for Alcon Superkit. Let me know if I may be of help.
See here: http://www.m3post.com/forums/showthread.php?t=669094
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      06-08-2013, 02:58 AM   #3
maicol76
194
Drives: E92 M3
Only Pagid?
      06-08-2013, 03:07 AM   #4
Richard@M-World
Originally Posted by maicol76 View Post
Only Pagid?
Yes I only carry Pagid because it suits the needs of track day drivers - ultra low wear, fade resistance, low operating costs, excellent modulation...
      06-08-2013, 05:05 PM   #5
klammer
97
Drives: 11 spc gry m3 e90, 19 X5
I use carbotechs on mine. Not sure about others. I did like the pagids more but the carbotechs were cheaper.
mods: track ready stuff
      06-10-2013, 11:52 AM   #6
maicol76
194
Drives: E92 M3
Oh thanks, KLammer.
Which Carbotechs pads are good for trackday?
Nowdays, I'm using Ferodo 2500 or 3000.
      06-10-2013, 12:20 PM   #7
maicol76
194
Drives: E92 M3
And,
I sent email
I'm using Alcon Superkit for BMW E92 M3, and love EBC pads so much.
Are there available pads for this BBK?
If not, I hope to suggest that EBC produce pads(yellow, blue and orange) for this famous BBK.
I received reply from EBC.
Hi,
Can you let us have a pad outline drawing please? We will need to know the overall length and height of the metal back plate. We should then be able to identify it for you.
Best regards
Bob Sketchley
Automotive Technical Dept.
Freeman Automotive (UK) Limited
Tel: 01604 583344
Could you give me some advice and technical information about pads for superkit?
      06-10-2013, 04:03 PM   #8
klammer
97
I use the carbotechs xp12 up front and 10's in the rear for the track. Not sure about the technical drawings. Sometimes you need to just send them a set of pads for a template, but that costs dollars, as I found with Endless.
      06-18-2013, 09:28 PM   #9
maicol76
194
Drives: E92 M3
Could you give me an information of Carbotech pads(part NO.)?
      06-18-2013, 09:31 PM   #10
italyix
italyix's Avatar
Drives: '08 E90 M3
http://www.ctbrakes.com/calipers.asp?Make=Alcon_Calipers
Mods: too many the list wont fit in the sig page. PM me
Tesla Referral code: http://ts.la/juliana77782
      06-19-2013, 01:40 AM   #11
maicol76
194
Drives: E92 M3
hey italyix
I already checked this page a few weeks ago. already.
Here is email between Carbotech and me
l'll be appreciate if you give me some advice about available Carbotech pads for superkit.
We will need more info from you on which kit you have before we can give you part numbers and prices.
Thanks-
Mike Jr.
I attached BBK drawing files that I have.
Do you have any drawings of the pads that are used in these calipers?
No.
This drwaings were downloaded from Alconusa.com.
M3post member using Alcon superkit with Carbotech pads recommended your pads instead of expensive Pagid pads.
Yes, I found the same one's using your car info.
It appears that they pads could be 1 of a couple different shapes from the pictures, but there is no guarantee that the pad pictures with the kits are the actual pads used in the kit.
It looks like the 4 piston is the CTMONO-4 shape but we cannot confirm the dimensions and the 6 piston looks to be the CTP7797, but again, we cannot confirm the dimensions.
Here is what we have on each of them:
CTMONO-4- 131mm x 62.5mm x 16mm (thick)
CTP7797- 163mm x 69.5mm x 18mm (thick)
Let me know what you can find out and we will go from there.
Thanks again!
So, I wanna Know exact part No. before order
m3post
