BMW M3 Forum (E90 E92)
BPM
      06-07-2013, 01:44 PM   #1
squartus
Drives: 2010 E92 M3 6MT
2010 E92 BMW M3  [10.00]
Poping sound during cornering
I have a 2010 e92 M3, have had it about 2 months but have noticed sometimes when I make a hard left corner my front right side makes a loud metallic poping sound, also sometimes when just backing out of somewhere slow but turning steering wheel hard it does it as well.
Did it with stock wheels/tires and my new ones so don't think its related to wheels. Any thoughts?
Thanks!
4.4L LC stroker/ESS VT2-625/Volk te37 sl's/AA exhaust/DSS Carbon Fiber driveshaft/ARH Headers.. etc
      06-09-2013, 08:36 AM   #2
squartus
bump
      06-09-2013, 09:29 AM   #3
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
Drives: '11 E92 M3 ZCP | F80 M3 CS
I have had the exact sound during the first 10-20kmiles, but has since disappeared. Have had my suspension inspected but no obvious problems or causes. I would just live with it unless it gets worse or becomes easily reproducible.
I do track my car often and have had no issues with the suspension or steering.
      06-09-2013, 11:25 AM   #4
mosx
The mod bug has bitten.
Drives: 2008 M3 Sedan
2008 BMW M3  [0.00]
My 08 does this too. Had everything looked at and the suspension is good. Dealer said it might be the plastics/dash/windows/gremlins making the noise. They offered to remove the dash board and try and fix it but I declined.
      06-09-2013, 02:58 PM   #5
squartus
Gotcha, thanks guys. Car only has 12k miles on it so hopefully will stop around 20k mark
      06-09-2013, 08:16 PM   #6
rngrjag
30
Drives: E92 M3 ZCP 6MT
Don't know what a "Poping" sound is (thread title), not being a Papal scholar or being religious, but damn that sounds serious--confession, perhaps? Not sure even BMW service will be able to figure that out. Good luck with the car's exorcism.
      06-09-2013, 08:38 PM   #7
rngrjag
30
Originally Posted by Lute View Post
Popping sound is usually associated with the differential.
Sure, Lute, but what about a "Poping sound?"
      06-09-2013, 09:02 PM   #8
larryn
Is the poping sound accompanied with a white smoke emission? If so, I know what is going on.
      06-09-2013, 09:15 PM   #9
spdy330
spdy330's Avatar
Drives: 05 Tundra, 15 FIT, 17 CRV
Motor mount???
If you will be purchasing ANY AT&T services online or in store could you mention that you were referred by me? My Employee Referral ID is eo4489. This would be a great help and it costs you nothing, thank you!
      06-09-2013, 10:12 PM   #10
Vic311
Drives: 2011 e92 M3
Originally Posted by spdy330 View Post
Motor mount???
Doubtful, on a car with only 12K miles
      06-09-2013, 10:41 PM   #11
squartus
Only comes from the front right corner somewhere, doesn't seem to affect handling or suspension etc. Only does it once in awhile or when im taking a aggressive left corner.
      06-13-2013, 02:26 AM   #12
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
You can hear it in these vids of mine:
Between 47-49 seconds
Between 3m09s and 3m11s
      06-13-2013, 12:45 PM   #13
squartus
Thanks for vids, hmm mine seems a good bit louder than that
      06-13-2013, 03:10 PM   #14
Rostasteve
9
Drives: 08 E90 Jerez Black M3
Check your swaybar end-links...they could be loose or shot. If they're loose/shot, they'll make a single loud clicking/popping sound under hard cornering or going over speedbumps/driveways (when one wheel hits the bump before the other). Track driving makes them fail faster. Aside from the clicking/popping there should be no other negative sensations. Check your other suspension bolts while you're at it too.
I had this on my other cars after upgrading the swaybars, and endlinks were always at fault. But they can fail with stock sway bars too.
      06-13-2013, 06:41 PM   #15
Mpatient
ScantilyClad
Drives: e90M3//e368//e28m5
I noticed my 08 was doing this with oem shocks and even after installing KWv3's. I then decided to lower the front another quarter inch and it stopped. Was wondering if it had something to do with the suspension hitting the bump stomps particularly on hard left hand turns.
      06-15-2013, 02:48 AM   #16
mlhj83
Scythe-Meister
mlhj83's Avatar
United Kingdom
90
The E9x M3 was designed to utilise the bump stops to contribute to spring rate, so hitting the bump stops won't produce odd noises.
m3post
