05-28-2013, 12:05 AM | #1 |
25
Rep 132
5w-40 for 135i
Hey guys I wanted to know what was the difference between 5w-30 and 40?? I don't know what I had in it when I first got the car, but after my oil change with the 5w-40my car seems a bit slower and my car just won't take off as fast.. Could this be due to the 5w-40??
05-28-2013, 12:30 AM | #2 | |
9
Rep 171
Well, the most obvious difference is the viscosity... In other words, the thickness (or better yet, resistance to flow) of the oil at a certain temperature. Using the wrong oil could mean you are offering less protection to your engine's components or causing unnecessary resistance. Why would you be using any oil that's not approved or within spec for your engine? Reminds me of people who try to run $1-a-Quart non-synthetic oil in their Bimmers. These are not Honda Civics... lol BMW recommends using "BMW Synthetic 5w-30" as an approved oil / viscosity. If you are using Mobil 1 Synthetic, then the proper viscosity would be 0w-40 (also an approved oil). Don't use anything outside of the range of these oils, unless you have a very good reason. |
05-28-2013, 12:44 AM | #4 |
9
Rep 171
05-28-2013, 03:48 AM | #6 |
European Editor
10589
Rep 22,992
As long as the oil used has a "LL-1" or "Long Life 1" rating you are fine. IF the oil has no LL rating then do not run it. You need to use a LL rated oil for the specially treated cylinder walls and piston rings in our engines. BMW says you can use an: 0w40, 0w30, 5w30 or a 5w40 LL-1 oil in the USA. Btw... you can also use a LL-4 rated oil where a LL-1 oil is spec'd, but not vice versa!
Maybe who ever changed you oil put too much oil in the engine. That would account for the slower reving. This is why I always do all my own oil changes myself. For my peace of mind. I use 0w40 because it covers the widest heat temperature range. I believe the BMW oil in the states is a 5w30 rated oil. Dack
05-28-2013, 09:04 AM | #7 | |
647
Rep 2,051
05-28-2013, 09:05 AM | #8 |
European Editor
10589
Rep 22,992
Post a picture. ?
05-28-2013, 10:12 AM | #9 | |
9
Rep 171
If they gave you BMW Full Syn. 5w-30 then you'll be fine. |
05-28-2013, 04:20 PM | #10 |
Let's save military ranks for those who earn it!
45
Rep 1,161
Drives: ...on the Ragged Edge
Mobil-1 0W40 is the top of the other approved oils that are permissible besides BMW's own oil.
For starting, the 0 is better than the 5, and for hot conditions, the 40 is better than the 30. I use Mobil-1 0W40 in all of my vehicles, and it's Mobil's best formula.
Richard
2013 BMW M3 Individual -- Fire Orange (sold) 2013 BMW X1 xDrive35i M-Sport -- Valencia Orange (sold) 2011 BMW 1-series M Coupe (#205/220) -- Valencia Orange (sold) 2009 BMW 135i M-Sport Coupe -- Space Grey (sold) |
05-28-2013, 04:26 PM | #11 | |
European Editor
10589
Rep 22,992
Dack
05-29-2013, 06:28 AM | #13 | ||
647
Rep 2,051
[QUOTE=AJx]
05-29-2013, 10:33 AM | #14 | |
9
Rep 171
BMW High Performance Syn. Oil from the dealership is "5w-30" in the US... The oil you used might be capable of running in a BMW (At what efficiency? Who knows...), but it's certainly not "BMW Oil". I've never once heard of BMW recommending the use of that oil in a 1 series. Will your car blow up when you start it in the morning? Probably not... but if your car is running that badly after a simple oil swap, then you might as well be running vegetable oil in your engine as far as I'm concerned. |
05-29-2013, 10:40 AM | #15 | |
Rep 28
06-05-2013, 12:46 PM | #17 | |
Other car was a submarine
94
Rep 704
http://bavauto.com/lview.asp?imgfile...ib500/1137.jpg |
