BMW M3 Forum (E90 E92)
BPM
      05-26-2013, 10:47 PM   #1
M3 Montreal
68
Drives: 2012 M3 SG ,DCT & 2011 S4
Replacement Brembo Rotors?
What's the best place to call for best pricing on replacement rotors for the Brembo 380 kit? Front rotors only and aiming for slotted.
Thanks
2012 E92-M3 Space Grey on Fox Red, DCT
2011 B8 S4 S-Tronic , Black on magma red
      05-27-2013, 02:53 PM   #2
sawzall
sawzall's Avatar
50
Drives: A Car
2012 911S  [10.00]
2011 911 GT3 RS  [0.00]
Thanks
Are you looking for the entire rotor or just the rings?
      05-27-2013, 08:19 PM   #3
M3 Montreal
68
Thanks
To be honest I wasn't aware we could change just the rings.
Lets go with just the rings. What would be a good supplier that won't charge BmW tax.
Zeckhausen or Raceshopper?
      05-27-2013, 09:46 PM   #4
Seattle M3
Drives: 2011 E90 M3 Comp Pack
Zeckhausen sells stoptech replacement rotors but they work great with Brembo hats. I used them on mine on had many track days with never anything but success.
      05-27-2013, 09:53 PM   #5
w00tw00t
w00tw00t's Avatar
Drives: 2016 MW M4
wait what! you mean I can install a stop tech ring on my brembo hat? you sure?? if its true then that's amazing cost savings! woooot!!
      05-28-2013, 04:59 PM   #6
THE TECH
BimmerPost Supporting Vendor
THE TECH's Avatar
307
Drives: BPMsport 2012 E92 M3
Try Marco at McKenna Performance!
      05-28-2013, 08:33 PM   #7
Chriskm3
Chriskm3's Avatar
59
Drives: M3
Let's see the side by size pics of brembo and stoptech rings once u get them
Vf supercharger + tune/H&R coils/ Akra evolution exhaust/Volk te37/ Rs-3 tires/ Brembos /TIal BOV/ OSS blacked out headlights/LUX v3/Led taillights/ Challenge Front lip/ P3 vent gauge/ F10 m5 shift mob/Matte black front grills/ And a funky air fresher
      05-29-2013, 07:04 AM   #8
Checkcaptain
Germany
549
Drives: BMW M4 GTS
How about that
http://www.m3post.com/forums/showthread.php?t=845890
      05-29-2013, 09:31 AM   #9
CSanto
636
Drives: 2015 BSM/SO M3
I would recommend talking to David at Zeck before buying stop tech replacement rotors.
We found out that they would not work for my kit.
This was one of his responses. David really know his stuff...like crazy knowledgeable.
Actually, I'm back to thinking those StopTech rotors will NOT work on your front kit. There are two monobloc 6-piston Brembo styles. One calls for pads with a 49mm radial depth. The specs on your kit call for pads with a 58mm radial depth. Since the StopTech 380x32mm AeroRotor has a maximum pad annulus of 51mm, that means it's got too small a swept area for the Brembo pads.
This is all assuming, of course, that your kit calls for Brembo pads of part number 07.9551.13. By any chance, do you know the Brembo pad part number for your kit?
If your pads are really XA5.71.M2, then the StopTech rotors SHOULD work after all.
      05-29-2013, 09:49 AM   #10
M3 Montreal
68
Did Brembo actually sell 2 different sizes for the North American market on the GT kits? Ill have to check. All I know is that my pads were Ferodo DS2500's.
Rest ill have to check
      05-29-2013, 10:12 AM   #11
CSanto
636
If i knew for a fact that stoptech rotors would work, I'd replace mine with those immediately and get new Ferodo pads.
      05-29-2013, 11:01 AM   #12
E92inSG
E92inSG's Avatar
553
Drives: F80 M3
All you have to do is check your part number for the Brembo kit that you have.
If it starts with 1M1.xxxx then you have the European version using M calipers and 380x32mm rotors which should allow you to use the stoptech replacement rings
If your part no starts with 1N1.xxxx then that is the standard US version using N calipers and 380x34mm rotors. Stoptech does not make replacement rings in this size.
I have the 1M1.xxxx version and have the stoptech rings on order. I will post updates once my parts get here but I do not expect that to be for another 2 weeks at least.
      05-29-2013, 11:55 AM   #13
Checkcaptain
Germany
549
Drives: BMW M4 GTS
US and Euro spec rotors are interchangeable.
It is only important to change the complete rotor with bell/hat.
Also the Euro spec rotors use smaller pads, so the complete Euro kit is about 5 lbs lighter per corner ;-) I used already US spec rotors as well as Euro spec rotors, also OEM GTS rotors and now finally Type 3 rotors. All works with the same caliper.
      05-29-2013, 01:52 PM   #14
Richard@M-World
Richard@M-World's Avatar
Drives: NASA TTA #92 M3
As far as I know, for 380 mm front GT kit, Brembo has only sold the N caliper with 380x34 mm rotor in the USA for E9X M3.
Kit number 1NX.9003A, where X is 1 for drilled, 2 for slotted.
The annulus for the brake rotor is 62 mm (aka radial depth).
I would also recommend changing out the mounting hardware when you change the discs.
Let me know if you need help sourcing them.
Authorized AiM Dealer - Solo/Solo DL | SmartyCam HD | www.m-world.us
      05-29-2013, 02:01 PM   #15
Richard@M-World
PS. Here are the pad shapes for Brembo N (top) and StopTech ST-60 (bottom). Clearly different as David mentioned.
      05-29-2013, 02:46 PM   #16
Checkcaptain
Germany
549
Drives: BMW M4 GTS
Euro spec is even less with 48mm
m3post
