05-14-2013, 02:31 PM | #1 |
New Lifetime Replacement Policy
814
Rep 11,738
:: ECS Tuning :: N62 Collapsible Water Pipe Kit|Ingenious? You Bet!
Here's an uncommonly creative solution to a common problem. Eliminate the notorious water pump transfer pipe leak on N62 4.4 and 4.8L engines with a collapsible pipe kit that saves hours of teardown. If you've been avoiding this job because you didn't want to go through the hassle and expense of pulling the heads and timing cover, this kit is the answer. Just pull the intake and valley pan and cut out the old pipe. Then insert and expand the collapsible pipe in a fraction of the time. This complete repair solution includes seals and lube for a leak-free repair. Click HERE to order today |
03-25-2015, 12:41 PM | #5 |
814
Rep 11,738
Tags |
coolant transfer, n62, pipe, valley pan, water pipe |
