      05-08-2013, 02:03 PM   #1
spray
10
Drives: 2008 bmw 135i
refuelling issue?
The car takes me forever to fuel, it continually shuts the pump off when I try to fill it. I have to keep starting and stopping. Anyone know why this happens?
      05-08-2013, 02:20 PM   #2
Vorsprung_CJB
Vorsprung_CJB's Avatar
8
Drives: AW 135i
No idea but I have the same problem, intermittently. I think it depends on the temperature and the type of nozzle on the pump. Seems to work better the closer to empty it is. Once it does get going I can finish filling to 100% though.
      05-08-2013, 02:44 PM   #3
JuuS
Drives: 2009 135i
Don't insert the nozzle all the way down. Choke up an inch or two.
      05-08-2013, 03:15 PM   #4
bmw1racer
bimmerphile, technogeek
bmw1racer's Avatar
Drives: 2012 E82 6MT Sport
I had the same problem at the beginning... Tilting up the pump handle a little more took care of it.
      05-08-2013, 04:06 PM   #5
tracer bullet
tracer bullet's Avatar
Drives: '11 135i , '15 X3 35i
Same here, seems more prone to happen at some gas stations around the neighborhood than others. I too just change the angle a little until it works.
No idea why, but that's how it is. So - your'e not crazy
      05-08-2013, 04:10 PM   #6
Dackelone
European Editor
Dackelone's Avatar
Germany
10539
Drives: N54 e82
I have had this issues since day one. Its always such a PITA to refill the (tiny) gas tank.
Mine always clicks off at 8 liters and then again at 15 liters on an empty tank. Once I get a few liters past those marks... the gas nozzle then works fine. Its just a PITA to get past 8L and 15L marks.
      05-09-2013, 07:11 AM   #7
Zombie1
Drives: BMW 135i 2010
Question Same here
I found if I just apply slight pressure down on the handle and it doesn't shut off
Mods:-Berkexhaust -alpinaB3flash -CobbAP -Cobb FMIC -ER charge pipe tialQ bov -M3 front sway bar -M3 subframe bushings -M3 front upper and lower control arms -M3 guide rods -M3 rear upper control arms -Mfactory LSD -defiv lockdown kit -TC Kline SA coilovers /camber plates- HP rear toe arms
