05-07-2013, 11:21 AM | #1 |
12
Rep 121
Recommended racing brake pads by those who track
Greetings for those who bring their e92m3 to the track.
What's your recommended racing brake pads that would fit the OEM calipers. Any reliable reasonable website retailers that you recommend. Thanks in advance. |
05-07-2013, 12:12 PM | #2 |
45
Rep 345
Drives: Many BMW's & Porsche's
Hawk DTC-60 or DTC-70
Fronts --> http://www.tcklineracing.com/webdocs...Details495.cfm Rears --> http://www.tcklineracing.com/webdocs...Details498.cfm That's all we use on our cars is Hawk pads....... Last edited by TC Kline Racing; 05-07-2013 at 12:23 PM.. |
05-07-2013, 12:13 PM | #3 |
11817
Rep 23,187
try pagids, performance friction, endless, or carbotech.
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
05-07-2013, 12:51 PM | #4 |
70
Rep 954
I've only logged 3 days on the track, but I used Performance Friction PFC01's. They were great on the track. Never a hint of fade or other issues.
But be warned if you are going to drive to/from home or a hotel or whatever they make your car sound like a dump truck. |
05-07-2013, 04:16 PM | #6 | |
BimmerPost Supporting Vendor
118
Rep 691
05-07-2013, 04:51 PM | #9 |
408
Rep 2,171
I'm on Pagid RS-29 and really like them, I run them on the street too and they seem fine. I will be switching to HAWK DTC 70/60 after I go through these because hawks are cheaper..
05-07-2013, 05:56 PM | #11 |
12
Rep 121
Thanks for the input guys!!! I'm suppose to upgrade to StopTech but there's not enough time installing it for an upcoming event, so I'm sticking to my OEM brake but it needs pads after 3 days in a row of tracking. =( Tires and wheels have to wait too - backorder on black ec7 according to Apex. =(
05-07-2013, 06:30 PM | #12 |
108
Rep 1,973
Drives: 2009 e92 MR "Civic" ///M3
I personally use carbotechs, XP20 Front and XP10 Rear, they're loud when cold, but like someone mentioned all track pads are.
Can't really go wrong with any of them, hawk, carbotech, pagids, PFC, endless, cobalt.. and so on and so on.. not sure if the last two come in M3 sizes.
|| DCT | ESS Tune | ACM Test-pipes | AA Green Filter | Swift Spec-R Springs | Stoptech ST-40 F || || My Youtube Channel ||
05-07-2013, 06:37 PM | #14 |
bigdaddyjulio
12
Rep 185
i love project U racing pads..
over 7 track event 1 set... search kautiongsr2011 youtube bunch of videos..
Big Daddy Julio
05-07-2013, 06:38 PM | #15 |
776
Rep 1,718
Drives: 2011 M3 Jet Black:ZCP, ZCV, ZP
have like PFC08 for track use and some street use, not loud when properly bedded
05-07-2013, 11:59 PM | #16 |
12
Rep 121
OK I'm really dumb when it comes to this but is it a must and/ or highly recommended to bleed and change the OEM brake fluid once I change to either Hawk DTC 70 or PFC01? Which fluid would you recommend!?
05-08-2013, 06:38 AM | #17 |
115
Rep 1,470
If you are swapping pads, Pagid RS-29. Squeal like crazy on the track but stop like crazy, too. Not sure I could live with them on the street. I swap back to street pads.
Stoptech 380mm/355mm | PFC08 / Pagid RS-29 | Akrapovic EVO - CF tips | Benvo Tune | MS UDP | AA air filter | MCS 2-way with 700/1000lb springs | Solid bushings and adjustable links | RD front swaybar | Apex EC-7 18x10 square 275/35-18 NT01 | Turner Race Studs | GT4 Brake Cooling | GT4 Power Steering Cooling | Alekshop Oil Cooler | Performance Steering Wheel | | CF Spoiler | Varis System 1 Full CF Diffuser | Extended Paddle Shifters | Schroth Quick Fit Pro | Turner Steering Rack Stops | Vorshlag Camber Plates
05-08-2013, 07:53 AM | #18 |
592
Rep 5,396
i run PFC-08. good price, and good pad for HPDE work IMO (though dont have experience with other race pads). i swap out for track work only and run stock pads on the street.
i got mine from harold at HPA. dont forget a good high temp fluid also. |
05-08-2013, 10:40 AM | #19 |
470
Rep 988
Any problems with uneven deposits with those that swap out for the track? In my experience with other cars, it seems that when a pad is bedded in with one rotor it feels best, but if you use multiple pads on one rotor the old pad material mixes with the new material causing uneven deposits and brake shudder. This seems to happen no matter what steps I take to clean the old material off and bed the new material.
That being said, are there any pads that seem more compliant with the oe pad as far as swaps go? Or am I better off with a dual purpose pad? |
05-08-2013, 07:57 PM | #21 | |
Thread killer
643
Rep 1,896
05-08-2013, 09:33 PM | #22 | |
592
Rep 5,396
why not take advantage of free pads for the street from BMW and run race pads exclusively for track? if you are tracking, run the best which is race pads. dont skimp on pads, brake fade sucks haha |
