      05-06-2013, 10:20 PM   #1
bandice
11
Drives: 130i
KW suspension E87
Hey guys,
So i have decided to invest in some coilovers although im having trouble choosing which ones!
Background: my BMW 130i E87 2006 is my daily driver and is currently equipped with the M-sport suspension. I would like a smoother suspension setup which can also be used for the track.
Along with coilovers i will be purchasing spacers and camber plates. I have had a look at the KW V2, V3 and clubsport. As far as i know the clubsport comes with adjustable camber?
Is there a large difference between the clubsport vs V2/V3, if i was to invest ~$3200 for the clubsport vs ~$1800 (V2), ~$450 (Vorshlag camber) = $2250 (V2 + camber).
Keen to hear your guys thoughts on what i should do
      05-07-2013, 03:54 PM   #2
andrey_gta
andrey_gta's Avatar
300
Drives: 130i coupé ;)
2008 BMW 128i  [10.00]
I have seen on these forums more KW v2 than v3.
I think people that want v3, have many more options at that budget
128i Sport 6MT converted to Euro 130i spec, 3.73 diff, tuned by evolve ~220 whp 207 wtq(ft-lb) SAE
In-progress: //M front arm, M3 rack, e36M lip Wishlist: Coils, n55 mnts, headers, LSD, e60 finn diff
"The 1-series is the last car that BMW engineered before the Germans, as a car-making culture, fell out of love with driving." - R&T 2013 135is
      05-07-2013, 04:16 PM   #3
631twentyeighteye
631twentyeighteye's Avatar
Drives: 08 335i
as far as im aware the diff between v2 and v3 is the difference in shock tuning capabilities, IE compression and rebound. There is no camber control on either unit. For your application unless you need the additional shock tuning the v3 provides i would say go v2 with dinan top hats and pocket the extra cash.
08 e93 335i MT
      05-11-2013, 09:58 PM   #4
strati1
Drives: a slow car fast
This^^the savings can go into m3 parts
//Mods: Golf Tee, red out tails, smoked fogs, B&G S2 Springs, Adjustable Koni Yellows, Vorshlag Camberplates, PSS 225 square, Macht Schnell 90mm studs, H&R spacers 15mm front 20mm rear (no rubbing), RPI scoops, K&N
      05-12-2013, 09:18 PM   #5
bandice
11
Drives: 130i
I was thinking of getting the m3 parts as well, im not entirely sure if i should install those parts myself though. would it be an expensive job if i were to get a mechanic to install the front control arm, wishbones and bushings?
      05-13-2013, 04:31 PM   #6
strati1
The rear bushing is the expensive part labor wise because they have to drop the rear subframe, but if you browse the suspension section you'll see the estimates that others have gotten.
Tags
130i, clubsport, e87, kw suspension
